Question about IBM 3584 (3584-1603) Tape Drive
We got the error on LED - 5b82 , Please tell us what is exact problem
Crown macrotech12000i power led is blinking no output sound.please tell me some repairing tips.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 01, 2016 | Televison & Video
What does it mean?
23426 (5B82) 1 Missing glyph U+XXXX (X) in 'XXXXX'.
Feb 24, 2015 | Computers & Internet
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
All led study
This is a fatal error. I can tell you exactly what is wrong but you need to press and hold the go button and post what light you see when you do that. I can then give you the exact item that has failed.
Mar 29, 2011 | HP LaserJet 1150 Printer
I have a mitsubishi ws-73711. I get a rapid flashing green light after unplugging and plugging back in. TV won't power up. I replaced the seven DM capacitors and the exact same thing is occuring. I am...
12 means no error. The device and menu buttons have to be pushed after unplugging and re-plugging for the error code operational check to work. If you have done that and if its still the same, then please tell me which LED is blinking so that I can help you. I remember your tv has 3 LEDs at the front.
Jan 08, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
Service error 02
SE 02
: Software Exception
Jan 12, 2010 | OKI B6500 Led Printer
I have a Sony ' Wega " about 6 years old 36 HD.. I turned it on and the stand by light blinks NO PICTURE.. OR SOUND AT FIRST IT MADE SOUND AND I THOUGHT PICTURE WAS GOING TO GO ON IT SHUT OFF...CAN YOU...
Please intimate exact model of Sony TV and how many times LED blinks as there would be 3 second pause between blinks so count blinks and let me know. This LED blink is an error code that will tell me problem section in TV.
Thanks.
Sep 07, 2009 | Sony Televison & Video
Abit beep code error and LED code of 87
Hi had similar problem today, 1 long 4 short beeps - so not exactly the same.
I ended up resetting the CMOS - and this fixed my problem.
Hope that helps!
Jun 06, 2009 | Abit AX8 Motherboard
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Printer
How many times it flashes?. It flashes in Orange or alternately in Orange/Green. This flashing LED has certain count that indicates the error occurs in the printer. To find out how to identify error indicated by flashing LED, please check here ;under article How to identify error indicator. Please tell me soon after knowing how many times the printer LED flashing.
Regards,
Jan 04, 2008 | Canon S400 InkJet Printer
IBM 3584 (3584-1603) Tape Drive Logo
254 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
