Question about Xerox FaxCentre F12 Laser Printer
I bought a xerox faxcentre f12 from my friend. My computer has window vista and I cannot find faxcentre f12 printer drive for my computer.
3 Suggested Answers
  • 48 Answers
SOURCE: Vista printer driver for a Xerox Workcentre Pro 635
try this....
http://www.xpvistasite.com/workcentre_pro_635_12490.htm
Posted on Feb 15, 2009
  • 93 Answers
SOURCE: Has anyone found a Windows
I am sorry to tell you but it appears that Windows 7 does not support this machine.
No drivers are found available on Xerox website. "see below link"
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/win7/en/Windows7_Matrix.pdf
None of the Fax Center printers are compatible.
Again i am sorry
Posted on Apr 19, 2011
Toner smears on all print outs. Looking for what part to replace.
Do you mean when the print comes out the toner smears on the paper when you touch it? If so, then it's the fuser that isn't working properly.
However, if you mean when the print comes out there is smeared toner in various places on your print, but the smears are fixed to the paper, then the cause is more complicated and could be caused by a number of different problems within the printer.
Mar 03, 2014 | Xerox FaxCentre F12 Laser Printer
Has anyone found a Windows 7 32 bit driver that will work with a Xerox FaxCentre F12. I've tried the Xerox Global Print PS driver with no luck. The printer is connected with USB.
Again i am sorry
Apr 19, 2011 | Xerox FaxCentre F12 Laser Printer
I Have canon xerox machine i want connect to my computer
if u have driver cd then download the driver & install it ur computer plz connect power cord to main supply & USB to computer if port conflict happens then plz release older device n add canon device
note canon & xerox are seperate company plz use copy word eg. canon copier,canon printer,canon fax machine etc
shahanawaz shaikh,India
Apr 12, 2011 | Xerox FAXCENTRE 2218 18PPM FAX
Hi, I have a Fuji Xerox 3200MFP. I can fax with no problem, scan with no problem. But I can not print or copy - anything that requires printing. The Status Window gives me "Printing... Please...
Most likely it's the driver. Try going to the Fuji website and see what drivers are available. It's possible that the driver your using isn't designed to work with your operating system (such as designed for Windows XP and your now using Windows 10, etc.)
Jun 16, 2017 | Xerox FaxCentre F12 Laser Printer
Xerox F12 will not power up
There is a fuse in the power supply, That is located under the paper catch tray.Just look to the right of the on off switch, You will see 2 silver phillips screws in that cover. Remove those and pop the cover off, it will POP, there is a tab holding it in place, so it will have alittle resistance in removing it.
You also will have to remove 3 screws on the power supply shield to access the power supply. some have 1 some have 2 fuses. If the supply is bad. Google a business called " the parts drop". Give Britt a call, he is very good to deal with and will have that part.
Mar 25, 2009 | Xerox FaxCentre F12 Laser Printer
try this....
Jan 04, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Red light on
That means your fuser most likely over heated, Will most likely have to be replaced.
Dec 16, 2008 | Xerox FaxCentre F12 Laser Printer
Restarting all data on printer
Here is how you reste the printer fo default settings.
The Clear System Data Memory option restores all the user-selectable options to the factory defaults.
  1. Press the [Menu / Exit] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button repeatedly to select [Memory Clear].
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select [Machine Setup].
  5. Press the [Enter] button.
  6. Press the [Left] or [Right] arrow button to select the required option: [Yes] or [No].
  7. Press the [Enter] button.
  8. Press the [Menu / Exit] button to return to the previous menu.
  9. Press the [Stop / Clear] button to return to the Standby mode
Nov 19, 2007 | Xerox FaxCentre F12 Laser Printer
Ac power
There are a couple of fuses in that power supply. But if it is a 412 or an F12 most likely you have developed cracks in the solder connections of that particular LVPS.
I would recommend replacing the LVPS.
Roughly a 250 dollar price on that power supply.
Sep 15, 2007 | Xerox FaxCentre F12 Laser Printer
Xerox FaxCentre F12 Laser Printer Logo
54 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
