Washer does not spin - Washing Machines
  • Washing Mach... Master
  • 822 Answers
Try brushes on motor.......
cheers
Posted on Mar 24, 2011
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Washer no longer spins.
with the washer set for spin and turned on...raise and lower the lid.
If it spins replace the timer.
If it does not spin...replace the direct drive coupling on the motor.
Mar 11, 2009 | Whirlpool LSQ9600L Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
