Question about Microwave Ovens
Okay, I got the cover off and removed the light bulb. Now - where can I purchase one. I tried a hardware store and Walmart....no luck
    Brigadier General:
  • 8,909 Answers
If you are in USA try www.partstore.com and in UK try www.espares.co.uk
Hope that helps.
Posted on Mar 24, 2011
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
HOW CAN I replace the lamp
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
In some models, the bulb is not removable from its mount, instead a bulb assembly must be purchased.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
May 18, 2013 | Samsung Microwave Ovens
Replace oven light bulb in FMV 156D
Hello Jim Rogosheske - To replace light bulbs, first I suggest disconnecting power to the microwave oven at the circuit breaker panel or by unplugging. To release cover, remove the screw on the light cover. Replace light bulbs with equivalent watt bulb available from your manufacturer or a parts distributor that they recommend. Bulbs are also available at most hardware stores or lighting centers. However, it is not recommended to use a bulb larger than 30 watts. Close light cover and secure with screw that was previously removed to release cover. Be aware that light cover may become very hot. Do not touch glass when light is on.
Oct 11, 2012 | Frigidaire FMV156DC Microwave Oven
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Light bulbs failedon my Sanyo model EM-G653 Can I replace them myself if so where do I purchase replacement bulbs.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If you don't have your instructions, please reply back with your brand and model number.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Aug 17, 2008 | Sanyo Microwave Ovens
I have a Quasar microwave, model MQ4440WW, and the light has burned out. I need to know how to remove the light bulb cover. Thank you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Microwave Ovens
How do you change the light bulb
over the range models
Once it's out of the wall, the outer cover (wrapper) will need to be removed.
counter top models
Jul 03, 2008 | Sharp Microwave Ovens
How do I change the light bulb in an Amana microwave model# ACM1580AS?
The whole metal cover should be removed, 2 special tamper proof screws are at the bottom back end use a small screw driver to pry or break the center post and then use torx screw driver to take it out, the bulb is a specialty bulb available in partselect.com for almost 30 bucks. good luck!
Jun 20, 2008 | Amana Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
