Question about Singer CE-100 Futura Computerized Sewing Machine
Just purchased windows 7 on laptop and it will not work,help. thanks, kathy bolin
  • Steve Mar 24, 2011
    Kathy -
    What company made the notebook (Acer, Dell, HP, etc.) and what model is it? Which version of Windows 7 did you buy -32 bit or 64 bit? Did you buy Windows 7 at a store or did you use an "Anytime Upgrade" option? Lastly, can you tell us the processor and amount of memory in your notebook? The more of these questions you can answer, the easier it will be to help you out.
  • Kathy Bolin
    Kathy Bolin Apr 12, 2013
    I have a HP Laptop with 64 Bit Windows 7 it was included on Laptop. Memory 4.00 GB.
    Novelist:
  • 233 Answers
YOUR PC RUNS WINDOWS 7 PRO OR ABOVE If you have Windows 7 Professional or Above, the solution torunning any XP software is fairly easy. Go to http://www.microsoft.com/windows/virtual-pc/download.aspx.Select your Windows 7 system and language, follow ALL the instructions, andMicrosoft will take you through to running XP mode on your Windows 7 system!Hurray! If you still have a problem with the USB cable being recognized, besure you're plugging it into the BACK of your machine, not through a hub or inone of the front ports. The program for the embroidery machine and the USBcable require more power than either of these allow, a technical point Singerdoesn't seem to be aware of. You should be fine to install the machine'ssoftware and run it from within the XP mode now. YOUR PC RUNS WINDOWS 7 HOME, STARTER OR VISTA Unfortunately, you'll need to have an original of Windows XPfor this, no way getting around it. Hopefully, you still have a copy of itlying around, or have a family member, neighbor or friend who does. Maybe acheap eBay buy? Doesn't matter if it's XP Pro or Home. This solution is quite abit more complicated, but you can get there. I run Windows 7 Home and I usethis solution to successfully run the embroidery software on my Singer FuturaCE-100; the application should be no different for any other machine requiringXP software and unable to run in either Vista or Windows 7, so take courage andcharge forward! You're going to want to download a free and SAFE softwarecalled VmWare Player. The download requires you to register, but there's nocost, it's updated regularly to keep it safe and has been thoroughly checkedout by a lot of geek experts out there. It's available at http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0.Fill in the required information, follow the instructions from the email you'resent, and download the software. Normally, the software will be downloaded tothe "Downloads" folder, unless you tell it to download elsewhere. Before you do anything else, place the Windows XP CD in yourCD drive. Make sure you have the registration number ready. Now go to the"Downloads" folder, double click on the VmWare installation file(Vmware-player-etc, etc) and follow the instructions to install. Once that isinstalled and you've rebooted your PC, double-click the icon on your desktopfor the VmWare Player. It will automatically open up with a Welcome screen.Click on "Create a New Virtual Machine." The next window will automaticallyshow under installer disc "Windows XP (Pro or Home" detected." Just click next.Enter the XP product key and keep entering any required information in theBLANK spots in the following screens. ANY spot filled in LEAVE ALONE. Now leave the PC alone-the process will take about 20minutes. Once it is done, VmWare Playerwill automatically launch the Tools Installer to integrate the virtual XP withyour computer. It may have to download or update the tools, so if you see ayellow banner at the bottom of your window, simply click Update Tools orInstall Tools depending on your situation. The tools will automaticallydownload and install, though you may have to approve a prompt or two. You will be able to click between folders on your Windows7/Vista system and the XP Virtual Machine to copy and paste your designs backand forth. I strongly suggest that whatever AntiVirus software you use on yourWindows 7/Vista you also install on the XP, as it will look for updates on theinternet and will thus be subject to any viruses out there. Make sure you useany firewall, as well, if you use something other than the XP default (you'llknow if you do). Now-close the VmPlayer completely. Don't restart it, closeit. Then reopen it. Do you get a message at the bottom telling you that the USBdevice connections are disabled? We have one more step, then, before installingthe embroidery machine's software. USB DEVICE CONNECTIONS DISABLED OR USB ARBITATION SERVICEFAILS/TERMINATED OR DEVICE ATTACHED TO THE SYSTEM IS NOT FUNCTIONING. Arggggh! One more thing? Okay, this is the really technicalpart. The problem is you have an AMD processor, not an Intel, in your machine.Congratulations on a smart purchase. VmPlayer has a little conflict with it.What I'm going to have you do may seem a little scary, but it is simple todo-and there is a backup so that if anything goes wrong we can fix it. JUSTDOUBLE CHECK EVERYTHING YOU DO BEFORE YOU DO IT. Okay. Your going to go into an area that's supposedly forbidden inyour computer-nonsense. Make a backup, be careful, and understand that otherswho know what they're doing have written, gone over, and done theseinstructions before you. And my PC works just fine WEEKS after I've done this! First, let's make a back up. Click onto the Start icon in thelower left hand side. See that blank line on the bottom just begging for somethingto be typed into it? Type "regedit" and hit ENTER. Click on FILE, EXPORT.Select DESKTOP on the right, name the file REG BACKUP and click SAVE. Now youhave made a full backup of your registry so if anything goes wrong you can goright back into "regedit" and go to FILE, IMPORT and select the file. See?Easy. Now. In the Registry Editor screen that you've opened, 1. ClickHKEY_LOCAL_MACHINESystemCurrentControlSetControlClass(36FC9E60-C465-11CF-8065-444553540000). 2. In the right hand panel, if UpperFilters exists, delete it. YES, delete it. 3. Go toHKEY_LOCAL_MACHINESystemCurrentControlSetServices. 4. Delete the usbfilter string. 5. Close the registry 6. You will want to go into Start, then Computer.Double Click on C, then WindowsSystem 32/Drivers. Scroll down to the fileusbfilter.sys and delete it. Now reboot your computer. FINALLY-REINSTALL YOUR EMBROIDERY SOFTWARE ACCORDING TO THEORIGINAL INSTRUCTIONS FROM YOUR MANUFACTURER. And yell at them for not paying for the original programmerof the software to update the software properly to operate on Vista and Windows7! I hope this helps everyone! It took a bit of research, butit's been well worth it. Happy embroidery!
Posted on Apr 14, 2011
  • Beth Millar Apr 15, 2013
    Go out tohttp://futura-support.com/. In the left hand pane, click on Windows 8 update (don't worry, we'll get you to Windows 7). Towards to right hand side of the screen, right of the apple, select your machine model. Then, on the lefthand side, you can select Software Updates. That will take you to the softward update you need. For some models, one update covers multiple versions of windows. Follow the instructions and see how it works for you. Let me know if it doesn't. I have a Desktop 64 Bit Windows 7, and my CE-150 has worked fine, but Laptops and desktops can often be different. We'll also see what's going on with your memory and RAM when the software is running if there's still problems.
Connecting to the computer
You should have received a cable with your XL-6000 that allows it to communicate with your computer. The one that came with my machine has a pin type connector on both ends and it's known as a null serial port connector. I had to purchase another cable because the pin connector would not work with my USB ports on my laptop. I ordered one online and it came with a CD (driver) that you have to load to your computer to make it work. Another thing was that my newer version of Windows (7) would not run the conversion software that came with the sewing machine. There is a feature in Windows 7 that allows you to run software made for previous versions of Windows. Go go Control Panel>Programs>Programs and Features>Run software made for previous versions of Windows. Hope this helps.
Apr 23, 2013 | Singer Quantum XL-6000 Computerized Sewing...
Conecting to a computer
Several things: You will need to purchase the PSW conversion software to be able to transfer embroidery designs to your sewing machine. Also, you should have received a cable with your XL-6000 that allows it to communicate with your computer. The one that came with my machine has a pin type connector on both ends and it's known as a null serial port connector. I had to purchase another cable because the pin connector would not work with my USB ports on my laptop. I ordered one online and it came with a CD (driver) that you have to load to your computer to make it work. Another thing was that my newer version of Windows (7) would not run the conversion software that came with the sewing machine. There is a feature in Windows 7 that allows you to run software made for previous versions of Windows. Go go Control Panel>Programs>Programs and Features>Run software made for previous versions of Windows. Hope this helps.
I have 3D Customizing and the newer reader/writer. The dongle works. The reader/writer is not found is what Customizing says. I have Windows 7 - any help will be greatly appreciated. Thank you.
3D will not run properly on a Windows 7 computer.The USB reader/writer will work fine with 5D software.
Trust me, I have tried extensively to get 3D to run on Windows 7. I ran it on Vista, for a while. Then an update to Windows ended that. I've never had it function normally on Windows 7.
Sep 12, 2011 | Husqvarna Viking 1
I have a designer 1. recently when i go to embroider, it starts fine then just goes hay wire and put teh embroider all over the place- not like the pattern. Sound to me like the emb. unit? thanks kathy
Hi Kathy, I'm sorry your Designer 1 is not feeling well.8*( It sounds like to me you need to get your embroidery unit re-calibrated by your local technician. When was the last time you had your machine serviced? Are the designs you are trying to embroider stock designs or your own designs? Have you tried resetting your machine by turning it off and back on again and let the machine calibrate again? (Take the hoop off before you do this and put it back on after you have selected your design) and try it again. Also how old is your machine? They had a recall on Des 1 purchased between 1999-2004 for a power supply problem. The serial # and recall info is on the Viking website at- www.husqvarnaviking.com. Also do you have enough clearance around your machine where the hoop is not hitting anything while it's embroidering that will throw it of big time! Hope something here helps you! If I can help you further you can also email me at- kats2sew@hotmail.com Happy Sewing!! Kathy ( from 1 Kathy to another)
Nov 02, 2010 | Husqvarna Designer I
I have 3D embroidery and just purchased a computer with windows 7. How do I reinstall my 3D
You need to make sure you have the latest version of 3D. If your CD version is not 7.25 go to the Husqvarna website and download the updates.
Next go to this website:
http://www.sewmuch4retirement.com/tips.html
Tip No.4 is the one you want. Click on it and follow the instructions. I have 3D Pro working just fine on 64-bit Windows 7. This website was started by the late and very much missed Janice Henning, who was the first Husqvarna embroidery sewing machine guru, IMHO. Thankfully her family are keeping the site up in tribute to her.
Oct 02, 2010 | Husqvarna Designer I
I just got a new computer with windows 7 in it. When i try to install the 3D software it doesn't work with windows 7. what can i do to get my program to work. When i install it it causes some of my...
3D can be made to work with Windows 7 - I have it working just fine on my 64-bit Win.7. Go to http://www.sewmuch4retirement.com/tips.html
Tip No.4 from the top is for you - these are the instructions I followed and they worked perfectly. You do need to be sure you have the latest version of 3D - it's 7.25 I believe.
Sep 16, 2010 | Husqvarna Designer I
My wife has a Singer C100 embroidery machine and I purchased a new laptop (windows 7) for her. When I tried to load on her ''Futura'' software it will not load. It went so far and then stopped. The files...
I've read about quite a few people having issues with Vista, so Windows 7 may not be supported yet, you may want to try calling singer or windows or both to see if there is some kind of patch or update
Jan 05, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
