Question about GE Refrigerators
I have a profile refrigerator top bottome model 541039 there is water underneath the crispers in the refrigerator part what is the cause and how can I fix this
  • 42 Answers
It sound like you have a frozen drain line. You have to go in from the front of the freezer and take the evaporator panel off to defrost the drain. Check to see if there is some food particles in the drain. When the drain line freezes up, the defrost water then spills into the refrigerator section through the air vents. This should get you back in shape.
Posted on Mar 24, 2011
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
FRIDGE IS LEAKING LOTS OF WATER UNDER THE CRISPERS
Good Afternoon Friend,
I understand your Frigidaire refrigerator, model# GLHT184TJ, is leaking water underneath the crispers. First, make sure the door is closed as well as you are not opening it frequently or for long periods of time. Secondly, make sure all foods and containers are covered. Lastly, make sure that all vegetables have been dried, if you have washed them, before storing them in the crisper drawers. All of the above can cause moisture inside your refrigerator, which can accumulate at the bottom of your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLHT184TJ Top Freezer...
Water collects at the bottom underneath the crisper drawers Model # P/N 241543915
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Frigidaire 20.5 Cu. Ft. Top-Mount...
Water collects at the bottom of the unit underneath the crispers and needs to sponged out every week or so.
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 24, 2010 | Frigidaire GLRT216TA Top Freezer...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Won't give me water anymore, still get ice and all the rest
SOME GE REFRIGERATORS HAD A PROBLEM FREEZING IN THE BOTTOM CRISPERS. IF THAT IS THE CASE YOU MAY HAVE A FROZEN WATER LINE , CHECK YOUR TEMP CONTROLS THEN LET IT UNTHAW
Jan 12, 2010 | GE Profile Arctica Stainless Steel Top...
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
