Question about Nokia BH-200 Wireless Headset
Hello, i've lost my bh-200 pin so i can't register it.. model bh-200 type hs-58w ic 661v-h558w
  • 436 Answers
The passkey is "0000" and here is a link to the user manual:
http://nds1.nokia.com/phones/files/main_page/Nokia_BH-200_UG_en.pdf
Posted on Mar 24, 2011
Type: RM-530, Model: E72-1, IMEI: 355239039112565, CODE: 0586208, FCC ID: PYARM-530, IC: 661V-RM530, WLAN: A87B39FB53B3
Hello:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Feb 02, 2013 | Nokia E72 Smartphone
My handset is displaying register HS. kindly provide me the required support to reslove the problem.
Please follow this procedure to register your handset
1. On the base station: press and hold the registration/paging key for min. 3 sec.
2. On the handset: within 60 sec. of pressing the registration/paging key;
Select MENU then Settings then OK then Handset then OK - Register HS then OK -
Enter the system PIN of the base station (the default PIN is 0000). Then press OK.
Registering now flashes in the display.
Registration takes approx. 1 minute to complete.
Thanks for using FixYa. Please do leave a vote for the help.
Nov 25, 2010 | Siemens Gigaset A490 Twin Cordless Phone
Hello\ screen pin cushioning
This is the most common failure on projection TV's regardless of the brand. It is caused by a failure of the convergence circuit. In particular, there are two STK IC chips, sometimes three depending on the model, and these are power amplifiers that drive the convergence yokes. They typically last 5-6 years and then they fail. Sometimes the failed IC will also burn out one or more of the low-ohm feedback resistors near the heat sink. If this is the case and you don't find/replace the burnt resistors, the picture will still not be converged, and within a short time of turning on the set, the new STK pack(s) can be damaged.
Jul 06, 2009 | Pioneer PRO-200 60" Rear Projection...
Tried to reregistering
Hi
Please try the following procedure:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
BizHub 250 Printer Driver
Hi, which version of Mac OS have you ? what are your problems ? also, i ve sent the ppd necessary for the Bh250 Mac driver on http://crackzfr.free.fr/bh250.sit. You'll have just to register it on your mac and, you'll be able to print on your Bh...
Jan 06, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Nokia BH-200 Wireless Headset Logo
246 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
