Question about Dell 1230C Laser Printer
I have a DELL 1230c color laser printer problem: WILL NOT PRINT ON THE RIGHT SIDE OF THE PAPER! jamesbullard@comcast.net
Corysf62
  • 188 Answers
SOURCE: Dell color laser duplex 3115 cn will not print on both sides of paper.
Mascmen7,
although I would still like you to let me know the service tag ( so I can check on your warranty ), I am going to take a stab at what I think you are having a problem with.
I have had several customers that have had difficulty with their Dell printers when in fact there was no hardware defect at all, but simply that the options were not set in their Driver.
One customer couldnt print from tray 2 because tray 2 was not "installed" in the driver.
See the image below. If you go to control panel and then printers and faxes, right click on your printer and then select properties. ( see image )
the last tab ( and i know it isn't easy to see here ) is marked as options.
Click there, and then make sure that the duplexer is either "available" as shown in the above driver properties window, or on some Dell printers, it actually shows a list on the left and the available options on the right. If this is the case for you, simply highlight the duplexer and "add" to move it to the columb on the right.
You would think that just installing the print driver would also insure the printer was added as configured, but sometimes it does not.
Let me know how you make out.
Cory
Posted on Nov 07, 2008
Corysf62
  • 188 Answers
SOURCE: Dell 3100 CN fades on right side of page only
This is caused by one of two things.
1) One of the handles on the toner cartridges is not seated all the way down. 90% of the time, this is the problem, and of that, most of the time it is the cyan cartridge that is not seated properly.
2) there is toner covering part of the print head. Sometimes this is just a temporary problem that can be fixed by simply cleaning the printhead lens with the cleaning wand. ( i will explain that in a moment). If cleaning the printhead works, but then the problem reappears shortly afterwards, then you have a more serious problem in that the developer housing for one of the toners is defective and leaking onto the printhead. When cleaning the printhead, make note of the most prominent color on the cleaning wand pad, as this is probably the defective housing's color.
To clean the print head
a) Open the front cover.
b) on the right hand side, slide the lite blue handle forward. This will open the access hole for the cleaning wand on the right hand side of the printer.
c) pull the cleaning wand out ALL OF THE WAY until it comes to a stop. Then slide the wand back in ALL THE WAY until it can not go in any further.
Repeat step "c" several times.
DO NOT move the wand back and forth unless you pull it all the way out and all the way back in. This will only smear the toner back and forth across the print head. when it is pulled all the way out it hits a lift that will lift it up and over the print head on the way back so it does not move backwards across the printhead.
the fuser is fine, and one of the two solutions above will fix your problem.
as I said though, if the problem is quick to return, then one of the developer housings are leaking.
Posted on Nov 17, 2008
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
  • 10 Answers
SOURCE: Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Posted on Mar 14, 2009
  • 4 Answers
SOURCE: Dell Color Laser 1320c printer. The left side of
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
Posted on Dec 10, 2010
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
Print on left side of paper lighter than right side
Are you using a photo paper designed for printing on both sides? Most one sided photo paper is only meant to be printed on one side, and the other side is not designed to show true colors.
May 02, 2013 | Dell 1320c Laser Printer
Doesn't print on the right side of the paper in
It is probably the transfer corona if you have already tried replacing the toner cartridge. The transfer corona charges the paper so that it will pull toner off the drum and it can go bad. Email HP and find out if the transfer corona is included in a drum replacement. If so, you need a new drum. If not, see if you can purchase and replace the transfer corona.
Feb 09, 2010 | Dell 3100cn Laser Printer
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
Vertical stripes
It sould be the print heads have gone bad.
I just had a Dell color laser that would print a 1" wide yellow line down the right side of the paper.
Replaced the print head unit, and problem solved.
Jul 29, 2008 | OKI C5100n Laser Printer
Dell 1230C Laser Printer Logo
253 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
