Question about Sony STR-DE685 Receiver
The 6.3 amp 125volt fuse blew. Do you know what the part number is so I can order a new fuse? Thanks, Fred
  • 436 Answers
A known manufacturer is BUSSMAN fuse BK/GMC-6.3A
you can find this brand everywhere. just make sure you do NOT use anything higher voltage.
good luck
Posted on Mar 24, 2011
65hm7 toshiba tv fuse
If ur referring to the 125volt,6.3 amp fuse it is At the rear of tv, where the power cord comes out of tv. U will need to remove the bottom back panel held by +-10 screws(much easier than it sounds) u will see fuse next to where power cord attaches to circuit board. Let me know if that helps or u need pix. Siralosha3@gmail.com
Feb 18, 2014 | Toshiba 65HM167 65" Projection Television
Thw menu box is destorted curving in at the middle and there is a halo effect with the letters and numbers so that you see them in red and a little above that in blue and a little above that in yellow.
THAT IS A CONVERGENCE FAILURE. BROUGHT ON BY CRACKED SOLDER ON THE FLYBACK TRANSFORMER THERE WILL BE AN OPEN FUSE NEAR THE FLYBACK IT LOOKS LIKE A RED BOX THAT FUSE WILL BE OPEN(BAD). IT IS A 600MILLIAMP FUSE THAT CAN BE REPLACED WITH A 1 AMP 125VOLT PICO FUSE THEN RESOLDER THE FLYBACK AND THAT WILL FIX THE TV FOR GOOD.
Dec 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a fuse for my pioneer vsx-305. It is a 6.3 amp 125Volt. I cannot find locally or on internet. Anyone know where to obtain one???
I don't know where you are, but if you're in the US (and guessing by your username, I'll bet you are), Radio Shack carries them. You could mail order them if you aren't near a store. In a pinch, you could also use a 6.5 amp fuse in place of the 6.3 amp. That's only 200 mA (milliamps, or thousandths of an amp) larger, which is only a small percent increase.
Oct 28, 2010 | Pioneer VSX-305 Receiver
Fuse keep blowing
Means that item the fuse is protecting is bad.Fusing unit is a good start replace it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Office Equipment & Supplies
I have a Lakewood mdl 5600/7 oil heater. Love it. It seems to have given up. I unplugged it for a while, relocated to different power source, still no lights or anything else. Internal fuse? If so, where?
I had the exact same problem and I took the front panel off and found the bottom thermostat was burned up when I bipassed it the heater worked so I know this is the problem. Its the small thermostat attached with two small screwes to the heater. It is a KSD301 16amp 125volt 160degree themostat but I am having trouble locating one. They seem to be chinese made and mostly have to be ordered in bulk. When/if I find one I will post again
Dec 13, 2009 | Lakewood Oil-Filled Electric Radiator...
Need part number for 6.3amp/125volt fuse inside unit
just go to radio shack and get another one.
May 20, 2009 | Onkyo TX-8511 Receiver
My kenwood compact disk payer rxd-a53 shut off now it keeps click
Your problem is caused by a blown fuse on the main board 6.3amp 125volt time delay fuse replace with the exact same type. The reason the fuse blew is most likely because they is a problem with the amp.
I suspect one of the finals is blown 2SD2560 or 2SB1647. Open the case and with the power unplugged replace the fuse, next unplug the 4pin connector from the amplifier board 3 black wires and one red.
now plug in the RXD-A53 and turn it on. you should now have the display working and no clicking.
unplug it from the wall and reconnect the 4 pin connector and now plug it back in and turn it on if the fuse blows again take it to a qualified service technician, the above noted output transistors will run you about 6 bucks a piece they are 4 of them 2 of each for each channel plus labor.
Mar 02, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Sony STR-DE685 Receiver Logo
96 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
