Just want to know proper proceadure for hooking up Se-8 equalizer to my Au 719 amp
    Brigadier General:
  • 8,546 Answers
Both Sansui??
Look at the full description of this eBay sample.
The SE-8 input is on the far left and the output is on the far right.
http://cgi.ebay.com/SANSUI-SE-8-STEREO-GRAPHIC-EQUALIZER_W0QQitemZ170619070768QQcategoryZ3271QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D10%26pmod%3D290534609339%26ps%3D63%26clkid%3D7968742018396830220
The SE-8 also supports up to two tape decks or processors within its own Tape Loops.
The AU719
http://vintageaudio.dualpixel.com/photos/Sansui%20AU-719%2003.jpg
Attach the se8 in one of the two Tape Loops. OUTs to INs.
Posted on Mar 24, 2011
I HAVE A BSR 3000 EQ, A TECHNICS POWER AMP SE-9021K,AND A TECHNICS SU-9011K PRE AMP HOW DO I HOOK IT ALL UP?
Very easy.
SOURCE > PRE-AMP > EQUALIZER > POWER AMP.
Not sure why you want to do it, though. Your pre-amp already has an abundance of sophisticated tone controls and filters.
If I might venture a guess, you are trying to correct some serious deficit in your speakers or in your source. If you need sophisticated tone controls, filters, AND an equalizer, you need to ask yourself why ... and fix that problem.
Oct 12, 2012 | Audio Players & Recorders
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
Proper procedure for hook up to Au 719 sansui amp
This is an integrated amplifier so you connect both of your speakers to the speaker outputs making sure that you keep them in phase. Red or plus terminal on speaker to red or plus terminal on Amp and the same with the other channel. Then connect your input devices as they are marked on the rear of the amp. You didn't mention what devices you are trying to connect to it so give additional info if you need more help.
Mar 24, 2011 | Audio Players & Recorders
I wanna equalizer a jensen 760 but i can`t can you tell me how can i do?
Hello, if you want to put an equalizer on an amp then I would suggest you get a preamp style equalizer, non powered of course, take the rca output whichever one you want to use and conect it to the input on the equalizer. Then take the output from the equalizer and hook it up to the input on your amp. That's it. Most equalizers also have sub outputs, make sure you hook the correct output from the equalizer up to your amp. Also most have 3 outputs depending on the type you have. If you need more help just let me know, good luck
Aug 14, 2009 | Audiovox Jensen Power 760 Car Audio...
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Jun 11, 2009 | Kenwood KAC-719 Car Audio Amplifier
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
Oct 30, 2007 | Bose 901 VI Main / Stereo Speaker
123 people viewed this question
 Grubhead
Grubhead
