Valor flamenco unigas 2 fire ignites but wont stay on, assume this thermocouple problem how is thermocouple replaced
    Brigadier General:
  • 4,736 Answers
Valor uses either a Thermocouple or Thermopile, depending on the unit. In some cases, it has both. And, yes, your assumption is probably correct. Some thermocouples are a part of the Pilot Assembly, which means you have to replace entire pilot assembly. If you check you Owners Manual in the Parts Breakdown section, it will indicate if it is or not and whether you need a Thermocouple or Thermopile or both.
If you're not familiar with repairing gas fireplaces, replacing the parts listed above, can be a little challenging. Especially if you don't have the proper tools. But, before you jump on this project, try cleaning the Pilot Orifice first. You can easily do this, using canned compressed air with a straw nozzle (like you clean your computer with) by blowing out the pilot tip. And while you're at it, clean all around the pilot assembly with the canned air. If cleaning the pilot solved your problem, you're back in business. If it didn't you'll have to go the other route.
Hope this helps you solve the problem. Please be kind enough to rate my reply to you. Thanks!
Posted on Mar 24, 2011
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Valor Fireplace model 837 AN. It has a handles on upper left side that when depressed lights the burners. The burners are supposed to stay lit once the lever is released but it shuts all flame off...
Definitely, sounds like a problem with the Thermocouple or Thermopile (some of the Valor models use one or the other or both). But, before you jump the gun, be sure you hold the control valve knob in for at least one minuet before releasing it, when lighting the pilot. That way, the Thermocouple or Thermopile will have ample time to heat up.
Hope this helped you.
Mar 19, 2011 | Heating & Cooling
Initial problem was that fire was taking long time to light, no spark being generated intermittently. Now Gas fire seems to be going off on its own when it has been on for a while. Fire is the hole in the...
First, have you changed the battery in the ignition system? If you haven't this could be causing your ignition problem. In addition, the Thermocouple may need to be replaced to solve the problem of the burner flames going of on their own. That's assuming the pilot light is also going out when the burners go out. It would also be wise to check the vent pipe to make sure it's not obstructed in any way. As this also, could cause the flames to go out. Because there is a Safety Overload Switch, that automatically shuts the burner off is there is a gas and heat buildup/backup in the firebox.
As far as replacing the Thermocouple is concerned, this unit uses the same type of stand-alone Thermocouple, as the older DESA Vent-free gas log sets and fireplaces used. It's held in place with a saddle strap mounting and is fairly easy to replace.
These fireplaces are made in the UK and therefore, are more complicated to install, diagnose a problem and then solve it, than those made in the U.S.
Hope this has helped get you headed in the right direction.
Feb 25, 2011 | Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Valor uniflame 480 ignitor problem.On start when I press down the flame control switch and the ignitor I have a flame,but when I release the flane control switch the flame goes out.Ive been told the fire...
I also would assume the same. This is all that keeps the pilot light lit, is the thermocouple sending signal to the gas valve saying hey I am on and hot so turn on the gas and lets get things hot. Try cleaning the thermocouple with steel wool and make sure it is on the top of the flame for best results.If this does not do it replacing the thermocouple is next, they are cheap and easy to replace.
Dec 21, 2010 | Heating & Cooling
Cannot get the pilot light to ignite on my Valor Flamenco Unigas II when the ignition knob is pressed down. Have had the ignition battery out, but the voltage seems to be correct. Fire Serial No 005 344 No...
Is the clicker making the clicking noise? If not, it is most probably the spark generator which houses the battery. The part is still available online for about £40. It did the job for me.
Oct 10, 2010 | General Heating & Cooling
I have a valor hone flame gas fire. It is quite old now and I believe the ignition switch is faulty. Does this fire have a self generating ingier or ir there a battery ?
I believe the valor is self generating. Ours is also not working and we need to replace it. Any ideas where to purchase one?
Feb 10, 2010 | Valor Toys
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
We have a Valor Model 466 Black Beauty OXYSAFE Fire, when you turn the sparker on the fire lights and you hold it down for a short time but as soon as you release the ignition the flame cuts out. We have...
It sounds as though you have a bad thermocouple. Replacing the thermocouple which senses the heat from the flame should correct your problem. The thermocouple is a safety device which when working properly sends an electrical signal to the main gas valve that your pilot lite is on and holds the valve in the operational mode.
Nov 04, 2008 | Heating & Cooling
Heating & Cooling Logo
405 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
