Question about LG Dishwashers
LG dishwasher model LDS 5811ST returns LE error message after running a few minutes in Normal setting. Goes through most of cycle before returning LE message in Quick Wash cycle.
  • 2 more comments
  • dgavery Aug 03, 2008
    No number with LE code. This is a dishwasher, not a clothes washer. We bought this unit in 2006, and have always used Cascade dishwashing powder. Tried turning off circuit breaker for 10 minutes on error message (hard wired, not plugged in), still got same message afterward. Called the 800 number yesterday, was told the nearest technician is 65 miles away. Hence my trying FixYa.
  • dgavery Aug 05, 2008
    None of the suggestions worked
    The dishwasher has always been very quiet, and still is. It draws water in and actually went through most of the cycle using 'Quick Wash' before a series of bells followed by the LE error message. Under 'Normal Wash' it only goes for about 4 minutes before the bells and LE error message. In both cases, it leaves water in the dishwasher.
    This problem occurred for the 1st time on Sunday, 8/3/08. Worked fine prior to that.
    Master:
    Sergeant:
  • 462 Answers
From when is this problem prolonging and please tell us since the problem what all have u noticed weird abt it... any sounds...? HOw does it start... does it have problem in the starting.. please
Thankyou
Posted on Aug 05, 2008
  • Mohamed Ismail
    Mohamed Ismail Aug 05, 2008
    thanks for responding.. i suggest u to run ample washes without any detergents... this is to flush the deposited detergent in the dishwasher..
    thankyou
  • Mohamed Ismail
    thankyou
  • LG Master
  • 19,396 Answers
Do you get any number in error message?
Posted on Aug 03, 2008
  • 1 more comment
  • Ginko
    Ginko Aug 03, 2008
    Try unplugging the machine for ten minutes, sometimes this can clear the error message.
  • Ginko
    Ginko Aug 03, 2008
    "LE error code can be an indication of several different issues.
    The most common cause is over-sudsing in the machine. Many times owners
    experiencing the LE error code are using regular detergent. It is recommended to
    use a high efficiency or low sudsing detergent. Many of the leading detergent
    manufacturers have a high-efficiency (HE) selection. The HE detergents are
    designed for lower suds levels and enhanced cleaning performance in
    front-loading washers.
    Overloading the wash with too much laundry may also cause the LE error code. A
    good rule is to load the washer until the clothes in the drum are no more than
    three-fourths of the way up the window of the door. This will allow them
    sufficient room for tumbling. The clothing having sufficient room to tumble is
    more important than either the weight or the number of items in the washer. It
    is the tumbling action that provides the washing effect.
    Lastly, a breakdown in the signal between the microprocessor and the motor may
    cause the error code. This can occur if there is a loose wire, dislodged ball
    sensor, or if the shipping bolts are removed prior to situating the washer. . In
    this case, a servicer would need to take a look at the unit. In this case, you
    will need a service center to look at your unit. For service assistance, please
    visit our website at us.lgservice.com Click on "Service Center". Enter your
    zipcode and product type. Click search.
    In the event that you cannot find a service center, please call 1-800-243-0000
    for assistance. There, an agent will be able to provide you with an Authorized
    LG Service Center in your area."
    From error LE
  • Ginko
    Ginko Aug 05, 2008
    If nothing worked it means there is something wrong with the control board inside your appliance, in this case replace control board or call 1-800-243-0000 for repair assistance.
LG Dishwasher LDS5811ST does not drain last rinse out. LE code displayed. Did the shutoff of power. Most say PCB assembly, some asy control board - ?
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Feb 24, 2015 | LG 24 in. LDS 5811ST Stainless Steel...
LE code what is it???
most of the time a le means the motor. you should call for service it may have a 5 year wnty.
Feb 25, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Le error code what cani do
LE is a motor error The Motor is working abnormally.
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Aug 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
When I start a cycle after a few mins I get LE error code
I had a similar problem Check the wires a black wire was shorted in the door. Heat broke the insulation down. George
Mar 01, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG Dishwasher Mode LDS5811
Try checking the wiring in the door for breaks and repair by cutting and splicing with electrical tape. This site has the Service Manual: http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Nov 17, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Le code
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
In your case I suspect the motor first.
Aug 08, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
145 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
