Question about Sharp R-510HW Microwave Oven
My sharp carousel r-510 hwf microwave oven is not working. When it started, I lifted the door and it worked while I held it up a little. Now that won't work. Could it just be it needs an adjustment to the door? What can I try?
    Brigadier General:
  • 8,909 Answers
Door catches.
One of the latches may be damaged or misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Start" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Posted on Mar 24, 2011
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Microwave will not start
your safety door relay is way out of adjustment
Oct 01, 2009 | Sharp R-403HW Microwave Oven
Sharp Carousel will not turn on unless I lift gently on the door.
the door interlock switch needs adjusting or replacement
Mar 26, 2009 | Sharp R-1480 Microwave Oven
Sharp Carousel Model No. R-315F(S)C
this can the be door latch overriding the start
Apr 25, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Sharp R-510HW Microwave Oven Logo
90 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
