Question about Breitling Watches
When i take my watch off after a couple of days is it the norm that only after a day my watch has stopped.
    Sergeant:
  • 302 Answers
Yep, typical watch power reserve is about 40 hours. It can very widely but this is typical
Posted on Mar 24, 2011
Seiko instruction adjustment instructions day date
The crown ( the winder as used to be) will pull out one ,two, or three stops. Each stop does somthing different.e.g. 1 - hands, 2 - day, 3 - date. Sometimes, the second stop will do two functions - turn one way for day and the other for date.
Jul 22, 2014 | Seiko SGG713P1 Sapphire Crystal Analog...
My T touch is not responding
Even I see the same. But I got this repeatedly to the Authorised Service Personnel of TIssot in India. But this never got fixed. Anyways thanks for the guidance.
Cheers
Madhu
Jun 13, 2012 | Tissot T-Touch T33759851
Brand new Invicta Pro Diver Watch 0923. The watch will work fine for a few days and then just stop working. I will reset the time and it will work for another couple days and again stop working again. I...
If you have any problems with a new watch you should go first to the supplier and if they can't help, contact the maker.
Most makers have a service depot who can help you.
You can find your nearest service depot by going to the Invicta web site (http://www.invictawatch.com/) and clicking on "service " in the menu bar at the top and there is a link to instruction manuals.
The battery should be OK unless the watch has been part of a window display for a considerable time. (Most of the batteries I have used lasted 1-3 years).
May 04, 2011 | Watches
Watch stopped working 11 months after purchase. New battery fitted - watch stopped couple days later. Another new battery fitted (both by jewellers). Again, the watch stopped within 2 days. Can't find a...
It is best to go to a watchmaker for this issue. If the battery was improperly installed, it can damage the movement or contacts, which will mean the movement must be replaced. We see this issue often. Another common problem is that the oils from the installer's fingers may be causing a bad connection if the battery and the contacts are not properly cleaned. We would use the Pulse test to see if the watch has current, if so, the movement is bad mechanically, it must be replaced. If it has no current, we would check and clean all connections and replace the battery. If there is still no current (using Pulse diagnostic) then the movement is bad and it must be replaced.
Jan 19, 2011 | Tommy Hilfiger Sport Stainless Steel with...
Eco-drive watch stop working, after it was in jewelry box for over a year.
First, be sure that the stem is fully pressed in. Pulling out the stem to set the watch stops the action.
The Eco-Drive is still a battery watch. It just has a solar/light powered recharge system built in. The battery will run down after a year of no light. Place the Eco-Drive in bright sunlight for a couple of days in order to recharge the built-in battery. You may recharge the watch in fluorescent light as well, it just takes longer.
Dec 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
My cartier tank francaise watch stopped working after I didn't wear it for a couple days. Do you know how to get it to work again?
If your watch is automatic, then it is self winding and should start if you gently shake it from side to side a few minutes.
Automatic watches do thrive on being worn every day and if left unused will stop after a few days.
If it is a quartz watch, then take it back to the vendor and ask them to fix it.
Mar 10, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
Hi - took it off for 36 hrs - never had an issue - oyster submariner not moving now ... thanks for your help
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Rolex Day-Date President 118238 Wristwatch
Setting day and date - the day and date change at the wrong tome of day
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
Oct 20, 2009 | Seiko Watches
Hi i have a eco drive watch and it stopped for more than a month now , how can i get it repaired
You do not need any repairs, just put your watch under the bright lamp for a couple of days and it will restart again. The best place would be window sill and plenty of sunshine.
Jan 20, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
The alarm goes off like twice a day ,a lost the manual ,and i don't know how to stop the alarm to go off
Had the same problem on my timex/acqua; after reading a couple suggestions on this site, I held down adjust button at same time as start/stop and it worked after a second or so. Try any 2 buttons at once, one suggestion did 3 at once.
Nov 08, 2007 | Timex 48021 Wrist Watch
Watches Logo
351 people viewed this question
Top Breitling Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Breitling Watch Expert? Answer questions, earn points and help others
