Question about Whirlpool Duet GHW9150P Front Load Washer
Getting ready to move, is it hard to unhook - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 6,277 Answers
If your posting is complete (?) the answer is 'no'; it is not hard to unhook. Taps turned off and unscrew hoses and put them in the drum so they are not lost. Unhook (probably) the drain hose and attach as best as you can to the rear- with tie-wraps or something similar. Disconnect plug from electricity supply and do the same with the plug and cable. Those are the easy bits.
Now- ideally when moving a washer the transit bolts should be in place to stop the drum and suspension from thrashing about and becoming damaged. If the original transit bolts cannot be found, a get-around method is to remove the back and pack the interior around the drum with blocks of sponge and/or blankets or equivalent, paying particular attention to NOT disturbing or damaging any plugs, cables or hoses in the process! Careful handling and transportation should be requested ;-0)
I hope my rantings were what was asked for!
Good luck, John C
Posted on Mar 24, 2011
Testimonial: "have not tried it yet but will this weekend. thanks"
My 2001 dodge intrepid failed emissions says due o excessive of readiness monitors 'Not Ready'
you must not clear codes or unhook battery after doing what they call a drive cycle which resets monitors to a ready state. http://www.lhforums.net/forums/showthread.php?2755-OBD-II-and-your-Next-State-Inspection
press helpful button
Dec 18, 2015 | 2001 Dodge Intrepid
What is the drive cycle for a 2002 Yukon XL 1500
I don't understand "drive cycle". You can clear the codes by unhooking the battery for 5 minutes then repowering.
Jan 05, 2015 | 2002 GMC Yukon XL
I want to open the hole whirlpool washer to vork on the shocks so it wont move.
Unplug and drain it, IT is easier to drain if you use a wet and dry vacuum. Get some towels ready and unhook the water supply hoses. Lay the unit down on its side or back and you can then see the shocks and springs and bumpers by looking into the bottom of it. Some machines allow you top open the top cover where the lid is.
Jan 03, 2013 | Dishwashers
We just unhooked our computer to move it downstairs. then we rehooked it up and the wireless mouse won't work even after pushing the reset button on top. it's a wireless microsoft model..newer..2 years.
Presuming the batteries are good or recharged? Try new battery first
OR, go to ctrl panel and system and device manager and delete the mouse. then plug it in for discovery. It will reqquire the driver disk to install it probably, so have it ready.
please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Microsoft Wireless Optical Mouse
Unhooking Battery Cables
unhooking the battery won't clear the code it's still stored in the hard set memory go to shcucks and have them scan the computer ask them to see if the codes are cleared if not you can clear them they can't it is an OBDII car once you have cleared the problem drive it and see if it comes back, be sure to get the codes printed out before clearing the codes the mechanic will need them if it comes back, there are hard codes and soft codes soft codes can be reset by unhooking the battery but not hard codes. Don't bother with unhooking the battery.
May 27, 2009 | 2003 Chevrolet Cavalier
I moved washer and I think the basket is unhooked
Detach and reattach the cabinet.
This video will show you how to remove and replace the cabinet.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Just skip the steps in the middle of the video.
Mar 15, 2009 | Whirlpool LSR6332K Top Load Washer
My inputs dont work
I don't believe the moving and unhooking was the issue! First I would look inside to see if the ribbon like cable came loose,that goes from signal board (input board) to lcd controller. The lcd controller will be on the back of the lcd screen, you will see a small board under a metal cover.
Second It may have been a coincidence, and the signal board was starting to fail. There could be some visual issue's with board maybe some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). Good luck, I hope this was helpful!!
Mar 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Emission rediness codes on after repair & clear
unhook the battery for about ten minutes... make sure you have the code for the radio (if required)
Feb 26, 2009 | 2001 Dodge Dakota
Carrier stall
The most common causes for this problem are:1. The carrage has come unhooked from the guide belt. 2. The guide belt has gotton dirty. On the back side of the carrage is a clear plastic strip with hard to see lines on it. If this has gotten dirty, it can be cleaned with q-tips and isopropyle alcohol. If it has come unhooked, just move it up and down a little in the back of the carriage, it will usually slip back into place.
Jul 25, 2008 | Lexmark X85 All-In-One InkJet Printer
Whirlpool Duet GHW9150P Front Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal De
