Question about McCulloch Garden
I have a McMcullouch chain saw model 3214 it has become very hard to start. Cleaned the air filter and replaced the spark plug. After I do get it started it is almost impossible to restart when warm. If I remove the spark plug and connect the spark plug wire back to the plug and connect a short jumper cable from a fin on the cylinder and the other end to the ground side of the plug and pull the started I see a very weak looking spark.
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
steve_lima
  • 181 Answers
SOURCE: poulan chain saw P3314
pull the muffler off and check if the piston is scored,if it is you need to replace the piston and cylinder.
Posted on Jan 07, 2009
steve_lima
  • 181 Answers
SOURCE: weak spark on 55 rancher chain saw/ airgap on magneto
the air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Posted on Mar 12, 2009
lindsay836
  • 677 Answers
SOURCE: husqvarna 181 se chain saw
I would replace the spark plug, make SURE you have the correct gap. Make sure you are using the correct oil gas mix, I believe it is 40:1.
If that does not help you may have a bad coil.
Posted on Feb 05, 2010
  • 4088 Answers
SOURCE: Have a Mac 3214, fuel lines were rotten, replaced
The fuel metering needle in the lower carburetor chamber may have a bad rubber tip or the rubber diaphragm may be hard or cracked. McCullough fuel tanks vent through the cap (it should not have a gasket). Gravity plays no part in the carburetor fuel volume. Remove the spark plug (ignition off) and pull the engine through a few times without the choke on, but the throttle wide open to remove excess fuel in the crankcase (no smoking during this procedure). Make sure the plug is dry when you put it back. Hope this helps!
Posted on Apr 19, 2010
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 40 Chain Saw The saw has been unused for about a year -- before that, always served well. I purchased fresh petrol and a new spark plug, cleaned air filter etc. The I noticed: no spark at all,...
The model 40 has a single piece electronic ignition, it cannot be repaired it will have to be replaced, before replacing, check the air gap between the flywheel and the ignition unit, this should be 0.3mm, also diss connect the earth cut out wire from the terminal on the unit and try for a spark again, this will rule out any fault with the wire or the switch, the ignition works off speed of rotation so you will have to crank the start as if you were starting the machine.
May 13, 2011 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a Craftsman 2.5 Turbo 18" chainsaw. Yesterday it would start and run briefly and the die. I changed the sparkplug and cleaned the air filter and now the saw will not start. The plug is...
Seeing a lot of fuel line problems due to ethanol. Make sure your fuel lines and primer lines are in tact. If the fuel line has broken, you may also need to clean out the inlet screen in the carburetor which can also become clogged.
Feb 12, 2011 | Craftsman sears 18" Chain Saw Chain (...
Will not start
remove plug dip in gasoline and try to start there could be something inside the engine restricting fuel may need to look inside motor
May 28, 2010 | Husqvarna Chain Saw 20" Bar
Can't start my Chain Saw Husqvarna 350.
The fuel may have been replaced, but is the fuel filter clean or is the fuel line cracked? Even though you cleaned the spark plug, did you check to see if it has a spark? If not, maybe a new spark plug or check the wire to make sure there is nothing blocking where the wire and spark plug connect. Is the air filter clean? Just a few more things to check out...
May 14, 2010 | Husqvarna Chain Saw 20" Bar
I have a poulan pp4218avhd chain saw that won't sart. I have cleaned the spark arrestor & the air filter. I have replaced the spark plug with a correct gap and checked that it is getting a spark. I...
I have this saw and really like it. Does the the primer seem to work? Most problems on these saws can be traced back to cracked fuel lines. Either tank to primer, primer to carb, or carb return back to tank. I would recommend it the saw it more than 3 years old to replace all the fuel lines. Total cost about $5. Buy your fuel line at Ace Hardware.
May 05, 2010 | Poulan PP4218AV 18" Chain Saw
My poulan 360a chainsaw cuts out when used for 5 mins. when opening throttle to saw woods it does not respond and cuts out.it starts again ok but will not respond to throttle. it is ok when motor is cold.
Check the fuel filter for plugging, the fuel lines for hardness/cracking/splitting. Clean or replace the air filter. Clean the muffler if plugged. Make sure that the carburetor fasteners are tight. Check the spark plug condition--gap should be 0.020" and the insulator should be light to medium tan color. If still having problems, the carburetor may need to be cleaned and serviced. Hope this helps!
Apr 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Have a Mac 3214, fuel lines were rotten, replaced lines spark plug and air filter. Started saw ran fine. Shut off saw, heard a girgling sound took off carb cover had fuel filling carb above throttle blade,...
Apr 18, 2010 | McCulloch 10" Electric Pole / Chain Saw
Garden Logo
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
