Question about Ryobi 18" Chain Saw Repl Bar Model Ry10532
Hello, I have a TYOBI 18in. 40cc Chain Saw model No. RY10532. Problem is that oil isn't being supplied to chain to lube while running. How can I fix this issue w/o taking it to repair shop. Thanks in advance.
    Scholar:
  • 54 Answers
The bar groove has a hidden slot place close to one of the 2 bolts that hold the bar where the bottom of the chain groove is connected to the hole in the side. This side hole lines up with another hole in the metal plate covering the oil tank area - bent angles go away from the bar and you should see a free hole and slot system between the oil tank passing straight through to the bar and then on to the bar chain slot to get at the chain links. Sawdust will tend to clog up in here as it runs under the chain on the bottom, so your chain oil gets cut off naturally. You can use a paper clip to poke it out. The tension pip must go into the proper hole also, so just use hand tight on one bolt at first and check that the tension screw makes the bar move so that the chain is seen going up and down underneath. Now adjust so that only one pound of pull with your left hand on the chain underneath exposes three of the chain's teeth completely from the bar - no more than that and no less! Now tighten the two bar bolts to spec. This will change as the bar gets very hot. Next take two caps full of chain/bar oil and oil up all the chain before starting. It goes up to 12,000 rpm so you can never have too much oil. Click your chain brake back and forth to see it works perfect - if there is even a teaspoon of sawdust between the brake band and the centrifugal clutch you will just stall out. Also watch the way old timers do a file job, and exactly where on the bar and at what angle for each tooth, there is more to it than you would think which is why sawmill filer jobs are the highest pay of all the woodworkers jobs. A poor job or 5 hour maintenance time is indicated by the saw not cutting into the wood easily, an angled cut, bar smoking and burning of the wood. I noticed on wet hardwood like Walnut you have to increase this maintenance about 30 times more frequent.
Posted on Mar 24, 2011
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Fuel/oil ratio for ryobi ry10532 chain saw
The fuel Ration is 50:1
I have included a link to the owners manual if you need it
http://www.ryobitools.com/product_promotion/discontinued_manuals/chainsaws/RY10532_867_eng_00.pdf
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 01, 2011 | Ryobi Factory Reconditioned 18" 40cc...
I have a RY10532 chain saw and have not needed to refill the chain oil for two years of use. I have to manually add oil to the chain to continue use of the chain saw. I know the chain oiler is not working...
it can be a normal maintenance problem and should be a part of the service routine
The pumps can fail or the outlet becomes blocked from wood spoil
To use it and know of the problem for 2 years means that you do not regularly service the unit
Feb 28, 2018 | Ryobi 18" Chain Saw Repl Bar Model Ry10532
My Ryobi 40cc chainsaw saw runs strong, but the chain binds and will not turn. The safety break is not engaged and the chain is not tighten to tight. I think it maybe the sprocket but it does not look...
If your chain has recently jumped off the bar while running, your chain may have "burs" on the drive links (part of the chain that rides in the bar groove). These burs will make the chain rub the inside of the rails and thus bind the chain in the groove. You can file these off with a flat file if there aren't very many, but you may need to just replace the chain. You can find files, bars, chains & sprockets for your saw at PartsBuggy.com.
Jan 18, 2011 | Ryobi Factory Reconditioned 18" 40cc...
16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
May 17, 2010 | Remington 16" Electric Chain Saw
I have a poulon p4018wm chain saw that runns but after it gets hot you have to wait for 30-45 minutes before you can start it again
if it gets too hot say from dull blade or not enough lube on chain it can cause gasoline to change to a gas
May 18, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Have The split cylinders in the Ryobi RY10532 40cc chainsaws caused grinding problems?
check chain sprocket take a rag over chain and pull it around should be smooth rolling also check nose of bar there are rollers check them out lota sawdust can build up behind clutch/sprocket
Apr 08, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Ryobi 18" Chain Saw Repl Bar Model Ry10532 Logo
300 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
