Question about Samsung RL41SBTB (12.2 cu. ft.) Bottom Freezer Refrigerator
The freezer door has been shut but all the food has defrosted. there isn't a lot of water leaking out. The refridgerator is still cool. any ideas ith whats going on? will
  • 132 Answers
It could be a defrost problem
Either the defrost timer has failed or the defrost heater has failed
a technician can fix that for you
Posted on Mar 25, 2011
Top half of freezer not freezing, and fridge not cooling well
What is the model number of your refrigerator? I need to know that to help answer your questions. Does the wall of the freezer have a layer of frost building up as in this photo HERE?Hopefully this is only a defrost problem caused by a defective defrost control, defrost heater or defrost thermostat. Try defrosting the evaporator behind the rear wall of the freezer with a hair dryer. You also could turn off the refrigerator remove all the freezer contents and place a bucket of hot water and shut the door for a couple hours. Be aware that if there is a lot of frost that there may be water overflow to the floor below the refrigerator. If this is a defrost problem the frost behind the rear wall will look like this photo HERE If you defrost the evaporator manually the refrigerator will continue to cool good for up to a week depending on how much the doors are opened. This will give you time to find the model number located around the fresh food section door frame. Locate the model number and let me know the number so I can tell you what components may need to be changed, Thanks Sea Breeze
If after removal of the rear panel in the freezer you see something like this with only a few rows with frost on them like in this photo HERE the problem is a Freon leak
Apr 10, 2013 | Refrigerators
Freezer works ice maker leaks water into freezer compartment. Refridgerator cranked up all the way cold and throws warm air not cooling food it is 5 years old
sounds like its set to high on the cold selection, and it needs to actually defrost , setting the freezer to colder much of the time will worsen the problem, if you can unplug it for a day and let the machine defrost ( deice) then it will be able to actually function better, Ice causes the functions to not be able to work properly. the ice maker leak could be caused by the limit switch being frozen , remove the tray and make sure that the unit isn't clogged with ice, if it is,, leave the tray out while you have it unplugged, and it too will fix itself once the ice is removed
Jul 20, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Model # bx2255w Amana Refridgerator bottom freezer works but refridge isn't cooling any more. Is it time to retire our approx 15 year old fridge or is there an easy fix?
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
May 22, 2011 | Amana Refrigerators
Dripping water and freezer not very cold
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 26, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Fridge not cooling
need to replace the defrost thermostat , heres some useful information, go to :
http://www.acmehowto.com/howto/appliance/freezer/check/defrosthermo.php
Nov 10, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung RL41SBTB (12.2 cu. ft.) Bottom Freezer Refrigerator Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
