Question about Cameras
Would u send me instructions how to program my bc145xl thank u
  • 2,574 Answers
Please click on the link below:
How to Program a Bearcat BC-145XL
Posted on Mar 24, 2011
BC145xl. Where can I get frequencies?
Here's how to program;
How do you program Uniden Bearcat bc145xl
Go to this site and you'll see a U.S.map. Click on your state, then after click on your county and a list of freq's will be there for you.
https://www.radioreference.com/apps/db
Aug 31, 2015 | Uniden Radio Communications
I have a uniden bearcat bc145xl 16 channel scanning radio, every time I push the manual button, and try to put in a code I can't get all the frequency numbers put in. I don't know what I am doing w
When you press the manual button and then enter numbers it thinks you are entering channel numbers not frequencies.
Try manual button and then prog button.
Then enter the frequencies.
Hope this helps
Aug 18, 2017 | Radio Communications
I need instructions on how to program a Uniden BC145XL scanner
Most older Uniden scanners can be programmed in these five easy steps:
1. Press Manual 1 Manual (should be channel 1)
2. Enter a frequency
3. Press E
4. Press Manual to advance to the next channel
5. Repeat steps 2 to 4
If you want a manual, apparently you will have to buy one... Price is $6.00 (including shipping) unless otherwise indicated Old Owner's Manuals Available
or Bearcat Manuals from Vintage Manuals, Inc. I am not affiliated with either, and did not check whether they have your model.
Jul 09, 2010 | Radio Communications
How do I program my bc145xl scanner
I searched but could not find a manual for the BC145XL. Your keyboard looks identical to the UBC144XL though, so the instructions for it should work on your scanner. You can download the manual for the 144 here:
http://www.scribd.com/doc/2056189/UBC144XLT
Bill B
Feb 19, 2010 | Uniden BC244CLT Base Scanner
Cant get programed
Programming the BC350 is fairly straight forward, and the operating manual has very good step-by-step instructions. You can download and print the manual by following the link below. The programming instructions are detailed on pages 24 through 28.
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 31, 2009 | Uniden BC350C Base Scanner
I have a bc145xl and i dont know how to put in my frequency channels i got
I couldn't locate a manual for you, but the 16-channel BC145XL is a fairly typical Uniden scanner.
Turn the scanner power ON.
Press the MANUAL button to stop scanning.
Press the MANUAL button repeatedly to advance to the channel that you wish to program.
Enter the frequency that you wish to program, including the decimal point. Frequency range of your scanner is 29-54, 136-174, and 406-512MHz.
Press E (Enter) to cpmlete the process.
To continue programming, press MANUAL to advance to the next channel, and start the steps again.
Dec 09, 2009 | Uniden BC350C Base Scanner
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
Lost book to scanner its a uniden bearcat bc145xl 16 channel and dont know how to program it.please help
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
Jan 13, 2009 | Radio Communications
Uniden # bc145xl scanner
How do I program my Uniden Bearcat BC 145xl? I lost the booklet.....
Oct 29, 2007 | Radio Communications
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
