Question about Mitsubishi WS-65857 65" Rear Projection Television
Mitsubishi rear projection tv not getting high voltage to CRT guns
I have a Mitsubishi rear projection 65" tv. The back panel was off the tv and my cat got behind the tv. After she jumped out, the tv shut off. when I tried to turn it back on, there is no picture, but only sound. The guns in the back of the tv are not turned on at all, so I am assuming it may be a high voltage problem, but I am not sure, and I dont know how I would go about testing or fixing it. Please help, I do not want to part with this large tv.
  • donbrooks Jan 29, 2009
    MIts 65813 comes on. Guns will not come on.
No. There is no obvious problems with this tv. Nothing is wet, chewed, or obviously broken.
Posted on Aug 28, 2008
    Genius:
  • 2,920 Answers
Did the cat urinate iin the back of the tv?
My TV won't power on. Green light comes on, then off/ Error code 21
error code 2 1 is from the x ray protect or high voltage circuit. there are many individual components that can fail and cause that shutdown.
to repair you would need to be experienced at troubleshooting electronics and would probably also need a schematic diagram. or have a shop repair for you.
May 31, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Have a Sony KP-65WV600, already replaced d board once, and replaced convergence ic's once also. Now as soon as I turn unit on, turns to red screen and shuts off, video that is, audio works ok, noticed...
Check High voltage Block.After replacing ic's (STK convergence ic's) you need to adjust Black&White scale.Turn ALL screen adjustments to min.Turn TV on and adjust screen slowly for each gun (I would start with Red first ) when you came to point that you see red background with white lines across, at that point G2 is too high (that will cause TV to shut down,don't worry just lowered adjustment and turn tv back on) so adjust to proper voltage and do the same for each gun.After that, adjust focus for each gun (again all controls are on High Voltage Block and HVB is mounted on front of your tv after you take speaker gril out) black box with 6 controls' screen RGB, focus RGB .
You should do that in dark room in order to get perfect Black&White scale,when all guns are adjusted properly you will see grey picture.Make sure 'Color" adjustment on your display is down to 0. Another step is convergence adjustment ,Flash Focus etc.If TV stil shuts off after all, your Red picture tube is short inside,take crt pcb from tube,make sure TV is unpluged from power before that, and turn Tv on .If stays On tube need replacment...good luck)
Aug 22, 2011 | Sony KP-65WV600 65" Rear Projection...
Mitsubishi WS-65513 65' The red keeps going out
It could be a loose component video cable, check your TV menu or another device when it goes out. If you have red in the menu or other device, it cannot be your CRT. The Crt is somewhat hard to replace but if everything goes great it isn't too bad. I usually mark all the yokes and magnets with a marker so I can put them right back in the same place and the picture should be about the same. Sometimes you need to do a lot of adjustment and that is when it can get tricky, kind of depends on how "identical" the new CRT is to your old one.
Let me know how I can help
Jun 09, 2010 | Mitsubishi WS-65513 65" Rear Projection...
No picture, high voltage cable sparks at left tube/gun at turn on
It sounds like you have a shorted picture tube.
You should call a good TV Tech to confirm this and get an estimate.
Jul 29, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Red convergence problem - Mitsubishi 65
It sounds like your red gun might be close to going, we had the same problem our tv. The red was off and couldnt really be adjusted but the others were alright. We were told that the red gun was nearing the end of its life and it could cost upwards of $1000 to fix, so we just got a new tv. i would suggest having a tv tech come out and look just to make sure, but thats wut it sounds like.
Oct 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No Green CRT projection
check the high voltage supply. each gun have a single input. be very careful, high voltage (1000v).
you are looking to buy a high voltage transformer. it is not cheap, and it is not easy to find.
Oct 14, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Yes my nickname is cztop i have a mitsubishi big screen tv & need guns ajusted
try unplugging tv for 30 minutes remove all speaker away from tv and anything magnetic after 30 mins turn back on try that
Aug 23, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI 65" WIDESCREEN MODEL WS 65809 (GREEN GONE, SMALL RED LINES)
in the front cover turn up screens on all colors till you see retrace lines, then back them down to where dissappear. enless you know the correct voltage to set it. as for the green. i would try the red crt on the green and see if it looks ok. if so then replace crt circuit or check transistors on crt circuit may also need to change the driver on the heat sync.
Apr 09, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Color changes
Your tv has three crt guns that correspond to how it makes colors.
If its just one color acting weird it might be the crt gun for red. That sucks cause it will be hard to replace. I think its possible to fix it but it might not be worth it... Sorry...
Feb 20, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65857 65" Rear Projection Television Logo
213 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
