Question about Intermatic INC ST01AC DIGITAL IN WALL TIMER
Instructions on how to set termatic Time All D111
Open following link to identify D111 timer:
http://www.tesvacances.com/products/intermatic+time+all.aspx
Intermatic no longer shows that manual:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It appears as though you push down the trippers and rotate around until tripper is set at on-off times of your choosing. The trippers could also be removable, but I cannot tell.
There is a black and orange tripper but I do not know which is ON and which is OFF. You will have to experiment, or words on-off might be printed on tripper.
Clock motor located inside timer rotates dial as time passes, and trippers move lever that turns load on-off.
Manually rotate timer dial clockwise until current time lines up with a mark.
I cannot see current time mark, but there should be a mark that shows where dial is rotated to set current time.
There is probably also an override switch on side of timer. You can experiment which position switch should be set to.
If free instructions above are not perfect, then do not hesitate to add a comment and include photo of your timer, so I can see the product more clearly. Also say if you have both trippers, and if dial rotates as time passes that would indicate if timer is operable, and take photo of timer switch so expert can see clearly since expert is not at your home with hands on the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 24, 2011
I replaced the heating element in my dryer (GE model#DPSB620EC4WW) and am putting it back together. I am uncertain where the wires go on the control panel. There is one gey, one purple, and 2 black that...
There should be a tech envelope in the console labeled "tech data" that has the wiring diagram on it. Dig thru that envelope and you should have the termation points you need. If not I am still looking for the wiring diagram and will respond with it when located. Be patient because I may have to download a service manual.
Kelly
Aug 21, 2011 | Dryers
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
WE HAVE THE SSC960 SYSTEM AND 3 CAMERAS
I would advise possibly getting a quad to view all 4 cameras. You can also check on the back of the DVR if there is any other place to plug your monitor into. Usually there is a spot port and a monitor port. One will give you the split screen without using a quad. Any camera should work on your system. You would just need to buy a prefabricated cable if you are not familiar with termating BNC connectors. I have a site below that was helpful when installing the cameras at my house. Hope this was helpful.
http://www.123securityproducts.com/
Jan 17, 2010 | Samsung SSC-960 VHS VCR
Toyota ATF WS
The fluid for your car is the new Dexron 6, this replaced Dexron 3 (D111), this is the best fluid for the trans, Toyota ATF-WS (World Standard) Automatic Transmission Fluid used in certain 2004-2008 vehicles is NOT compatible with Toyota T-IV or Dexron ATF
Apr 08, 2009 | 2006 Hyundai Sonata
HDTV Projection monitor will not power on
Problem solved. With the set plugged in(but in stand by mode) I took the back off. There are two LED on the left board that, if on, identify a problem. The D111 LED was on. I traced it to a blown fuse-FU303 which is the center fuse, about the middle of the center circuit board. I tried replacing the fuse 3 times, after each, it would blow. Another chat section on your site suggested using a 5a(up from 4a) fuse; that fixed the problem. The set works great. Your IC fix worked fine, although getting the boards out  was quite a chore. Your link to the instructions on how to R/R the IC chips was invaluable, and the set of instructions on the process was very complete and well done. Thanks for all of your help!
Jan 18, 2009 | Televison & Video
Thermostat for 318i 3 series E36
Follow the upper hose to the engine. The hose should be connected to the neck of the thermostat housing. Remove the housing and replace the thermostat. I suggest you buy the Chilton manual or equivalent for that car. That will help you a lot. Most parts stores have them or you can buy them online.
Jun 19, 2008 | 1996 BMW 318
Instructions
i have a CL-5073
to set time:
HOLD "Set" for 3 seconds
then use "Mode" to browse through option
When you get the time setting hit "St/Sp" to set the time
When you're done press "Set"
hope this helps
May 03, 2008 | Columbia All Sport Digital watch
Intermatic  INC ST01AC DIGITAL IN WALL TIMER Logo
739 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
