Question about Maytag Jetclean II MDBH945AWS Stainless Steel Built-in Dishwasher
It is just not cleaning the dishes. Runs - OK
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Posted on Mar 26, 2011
Hobart lx18h fills heats water runs cycle but does not get dishes clean
Hi, there is a build up of junk and mold behind the filter screen and under the cover at the bottom of the dishwasher where you will also find standing water that was not draining.
Clean it up and your dishes will come out clean..
Jun 28, 2011 | Dishwashers
Dishwasher is not cleaning dishes
i would suspect spraying arms or water temp not working.adrian,,,
Jul 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
Miele dishwasher G 1232 sc no longer dries
the problem with not drying is normally three things
1. not adding enough rinse aid to the compartment (dispenser) and adding to much soap.
ex rinse aid helps with drying,spots and cleanind the dishes. so if is none then you want get maximum cleaning.
3. make sure you run the faucet to get the hottest waster going into the machine this will make the other two do it job better because as you know you cant clean dishes properly in cold water.if this info helped please send me 4 thumbs post , thanks
Mar 01, 2010 | Dishwashers
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Indesit D63 dishwasher dishes not getting clean
check that the arms top and bottom turn freely and are not blocked.also if you use tablets,then you do not need to use rinse aid in the door,the coating could be due to over rinse aid as the tablets have this in,if these are ok you may benifit from putting a good quality cleaner through if
May 05, 2009 | Indesit 24 in. D63 Free-standing...
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishes are coming out with a thick cloudy film
Most dishwasher detergents now have some sort of rinse agent already in them. If this is the case don't add it to your dispenser once it runs out. Too much rinse agent can cause clouding.
Feb 18, 2009 | Kenmore 24 in. 16283 Built-in Dishwasher
Maytag Jetclean  II MDBH945AWS Stainless Steel Built-in Dishwasher Logo
104 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
