Question about Bernina Artista 180
I have a Brinina Artistia 180. I am trying to make buttonholes for dress. I have forgotten how to set the buttonhole size and cannot get it to make the correct size buttonhole. I have a window that measures the button for me. That says 14mm. Can you remind me how to set the size?
  • 436 Answers
Unfortunatly i could not find any free manuals out htere but you can try contacting the manufacturer
http://www.bernina.com/content-n81-sEN.html
or buy a manual online:
http://www.sewusa.com/Sewing_Machine_Manuals/Bernina_Manuals/180_Instruction_Manual.htm
hope it helps.
Posted on Mar 24, 2011
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
How to make a button hole
I don't know that machine, but generally on older machines, you put a buttonhole foot on the machine, set one of the buttons in the back-end of the slot so that it adjusts the size needed automatically. Then you set the machine stitch setting on 1 and set the width to make a satin stitch (a close zig-zag) down one side of buttonhole. You sew until the buttonhole foot makes the button hit near the foot; it will stop you, basically. Then you change stitch dial to 2 to make the bottom of the buttonhole, then 3 to make the other side, then 4 to make the top side. Then you remove the fabric and cut open the buttonhole (I use FrayCheck fist) Try some buttonholes on scrap fabric first, you will figure it out by trial and error.
If your machine is newer, they automatically can sew a buttonhole, but each one does it differently, Sorry.
Dec 09, 2013 | Euro-Pro Sewing Machines
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
Not sure how to use the buttonhole foot J that came with my 712T machine. I guess I don't understand the sliding part. Are you suppose to guess at the buttonhole size or do you use the button somehow to...
The buttonhole foot slides open so that you may insert the button which you are making a button hole for so that it may be sized correctly.
Slide open the foot, place the buttin on the spot and slide it closed.
Turn the pattern selector off and back on to the buttonhole pattern to reset. (Do this each time you make a buttonhole to reset)
Pull down the buttonhole lever located up and to the left of the needle bar. Pull it ALL THE WAY DOWN so that it will be tripped by the buttonhole foot as it moves.
Set the stitch width to about 4 or 4.5.
Set the stitch length to a very tight stitch (but usually slightly higher than the recommended marking)
Set the upper tension on 3.
Use an appropriate stabilizer. This is the key to a good buttonhole.
Lower the foot on the fabric, ensuring that the foot goes down without springing forward or back.
Make a few practice buttonholes, adjusting the width and length untill you get what you are looking for.
Jan 16, 2010 | Janome MyExcel 3123
I keep getting the bl sound when trying to make automatic button
I'd forgotten to pull the little lever down that abuts onto the buttonhole foot! Simple!
Nov 28, 2008 | Janome Memory Craft 9000 Computerized...
The buttonholer doesn't work right.
Most sewing experts will tell you that the best buttonholes are made with the Singer Buttonhole attachment that has been available since the 1930's. It makes perfect buttonholes every time. Everyone complains about the modern machines not making great buttonholes and not working correctly. Just do a quick search on eBay for one of these vintage attachments and your problem is solved once and for all. Don't waste all the time and money trying to get your machine fixed to only find it does not make good buttonholes...the best solution has always been the buttonhole attachments made by Singer, which the professionals use even with modern machines. They can be found in low or slant shank.
Oct 04, 2008 | Singer 2662
Singer 7462 buttonholer
try adjusting the size, see if it changes the result and go from there, you might also want to ask other experts, sewing machines are not my speciality.
Sep 28, 2008 | Singer 7462 Mechanical Sewing Machine
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
313 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
