Question about Printronix Office Equipment & Supplies
Error code : E03E DSI CXIWX is the code we are getting .. can you let me know what that really is or cause it to code that way... only thing we did was change the ribbon..Norm
    New Friend:
  • 57 Answers
An ******* or unsupported
instruction was attempted
in the application
program.
1. Cycle Power. Run the print
job again. If the message
appears, load the latest
emulation software.
2. Cycle power. Run the print
appears, record the display
message and send it to your
next higher support facility.
Posted on Apr 13, 2016
5 Suggested Answers
  • 13 Answers
SOURCE: "warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
Posted on Jun 15, 2010
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a link to a picture of where the sensor is located: https://support.zebra.com/cpws/docs/xi3plus/140xi3plus/images/140xi3p021.jpg
I hope this helps!
Posted on May 13, 2008
  • 1456 Answers
SOURCE: Getting repeated "ribbon" error messages
Hello
Ensure that the printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
Check the printer cartridges and printheads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the printheads. If an ink cartridges is empty, replace it with a new one.
Make sure that the printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the printer software.
See if your computer's firewall is preventing the printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
Check the print settings in the printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the Solution Center.
Clean and align the printer cartridges. Open the software for your printer or the Solution Center to access these maintenance features.
Double-click on the printer icon in the systray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
Navigate to the website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the printer's specific error. Also check the "Software and Downloads" area for software and driver update.
Posted on Jun 17, 2011
elix0411
  • 3530 Answers
Welcome to Fixya
Try to clean the the parts below that would contribute with the "Ribbon" error message. a) Ribbon path b) Ribbon feed roller c) Ribbon guide and arm d) Ribbon feed sensorThank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jun 18, 2011
Error Code: E03E
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 07, 2016 | Printronix P7000 FormLine PN P700502...
ERROR CODE FOR DSI 052010-1
Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings; manually assign an IP address to the Nintendo DS.
Don't know how to find your router's security key?
Manually assign an IP address to your Nintendo DS.
For more help visit cbrtechsolutions
Jul 01, 2012 | Nintendo DSi Black Console
Codes
It's probably just an"ERROR CODE", and there actually quite simple to de-code.All you have to do is follow this web-link to"Nintendo Customer Service"and to the left were it says "ERROR CODE Lookup" you enter the"ERROR CODE", select a system(or in this case,the"Nintendo DSi) pick a language, and there it is the meaning of the "ERROR CODE".
Jan 20, 2012 | Nintendo DSi Black Console
Error code 299001
Here's what Nintendo has to say about this code:
Error Code: 299001 Nintendo DSi Shop
There appears to be a temporary issue with the Nintendo DSi Shop. Please wait awhile and try your connection again later.
If you have waited several hours but are still receiving this error code, please call 1-800-255-3700 for assistance.
In short, there's nothing necessarily wrong with your DSi, but if you get it repeatedly I suggest you call that number.
May 19, 2011 | Nintendo DSi Black Console
Error code 051099"1 nintendo dsi.trying to get
Error Code: 051099Was this information helpful?
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
Jan 30, 2011 | Nintendo DSi Matte Blue Console
Nintendo dsi getting error code 52103 for usb connection
it seems like cant find the server , search teh error code form nintendo .com
Apr 30, 2010 | Nintendo DSi Black Console
DSi error code 0000FE00 when switching on
I am having the same problem with my daughter's. I had to return the first one because of that code.. and now the second one has it too. I am out of the 90 day return policy period though. In my opinion, these things weren't quite ready to hit the shelves when they did.
Apr 08, 2010 | Nintendo DSi Black Console
Flash Card: R4i-SDHC Upgrade from http://www.r4i-sdhc.com/ My DSi has the version 1.3E Once I boot my DSi and I want to boot my R4i it says: An error has occurred, please turn the system off, bla bla.. I...
Hello DSi Gamer,
For any errors having to do with a R4 card, never look in the manual, all those error codes have other problems that a manual would even know how to handle. If you own a real R4i SDHC, then it should work fine on the DSi v1.4u. I'd update everything including your DSi, it should be safe now, as well as get the latest R4 SDHC softwarre on a freshly formatted micro sd card.
I bet that'll fix all your problems.
If you suspect that you have unstable fake clone version you can get a genuine card there too. http://www.dscardworld.com I managed to find this site after I got burned at a few others. Loved having my emails responded to because I had loads of questions, and they were quick to ship it. They test each card before sending them. US based support and shipping I believe.
Best of luck!
Sep 19, 2009 | Nintendo DSi White Console
Can't play ds fireline (100 games in 1) in dsi
The DSi blocks all flashcards that were released before it. Your card is one of those blocked cards, so you can't do much except return that and buy a DSi-compatible cart online. As for the region, the DSi hasn't been hacked yet so region changing isn't possible at the moment.
Jun 10, 2009 | Nintendo DSi Black Console
How do you unlock region code on DSi?
sounds like another new thing nintendo have done to screw us all up, i would suggest a dstt cart or r4 cart or summit but they dont support them eaither! either back to the shops 4 money back then buy in europe or wait until they bring thr dstt or r4 or n5 crt out which supports the dsi and go from there.
Apr 02, 2009 | Nintendo DSi White Console
2,767 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Nick
Vladimir Frolov
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
