You can usually download the Audio driver for your computer by going to the Manufacturer website of your Motherboard and searching in the support section there.If it is an Intel Motherboard
then follow the below steps to download your audio driver.
You can use the Intel Driver update utility,which automatically detects
and download the right drivers for your Intel products.To do this follow the instructions below.
1) Go to this link
http://www.intel.com/support/detect.htm2) Click on the button that says "Check your system for the latest updates"
3) If you get a warning confirmation window from Java,click Allow/Run,do the same for any
confirmation pop-up from windows as well.
4) Now the utility will start searching for the right drivers and display a list if available drivers,
like Graphics,Motherboard,Audio etc
5) Now click on the button "Expand All" to see the download links.
6) Finally Click on the "Download Now" button next to the driver you need to start downloading that particular
driver.
7) Once the download is over,navigate to the folder where you saved the downloaded file and rune the setup file
to install the driver.
Note:The Update utility needs java run time installed on your computer to run,If you have not installed it already
then you can do so from the following link
http://www.java.com/en/download/index.jsp And if your motherboard is not from Intel,then please provide the manufacture name and model
number and we will try to find your audio driver for you,hope it helped.
