Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Water freezes when going into ice maker model # ed25rfxfw01 whirlpool
  • 4,070 Answers
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Posted on Mar 24, 2011
2 Suggested Answers
  • 27 Answers
SOURCE: no ice in the icemaker
there may be some problem with water inlet solenoid valve. the coil or valve could be faulty
Posted on Mar 10, 2009
ED25RFXFW01 icemaker
Sounds like the=> W10408179 Dual Water Inlet Valve
has began to seep water at the valve and out through the ice maker fill tube and down into the ice bucket. About all you can do when this happens is replace the above W10408179 Dual Water Inlet Valve. I will be here should you have questions, Thanks Sea Breeze
How to test the valve can also be found HERE
Nov 08, 2012 | Whirlpool Refrigerators
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model ED2CHOXK005 Whirlpool refrigerator with ice maker the ice maker quit working still puts ouf water but no ice
The problem is most likely your water control valve for the ice maker. There are 2 one for ice maker and the other is for the dispenser. Fill your ice maker with tap water. Let it freeze and if it dumps and does not refill then the water control valve part number 2188542 let me know if you need more help, Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Whirlpool Refrigerators
WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
Jun 18, 2009 | U-Line BI-95
No ice in the icemaker
Mar 10, 2009 | Refrigerators
Whirlpool side by side refrigerator
hi there,
the freeze-up is caused by either a kink in the water line or a blocked air vent. check for both.
Nov 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
I have a Whirlpool Refrigerator Model ED25RFXFW01 that is very slow to make ice. It also gets stuck very often during the dumping cycle. Is it clogged up or what?
is the ice too big? if they are, the ice size adjustment needs to be adjusted. if the water to freeze is big then it takes a lot of time to freeze it and ice produce is slow. also you can check the pressure of the water to the ref, it could be very high pressure. i hope i was able to help.
Jul 05, 2008 | Whirlpool Refrigerators
Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
