Question about Panasonic KX-T7630 Corded Phone
I have lines 1, 2 and 12 hooked up. 1 & 2 have their own phone number and ring fine, line 12 has it's own phone number and won't ring at all. The line still blinks when someone is calling, and when I pick up it is connected, but it is always silent, which is a pain! How can I make my line 12 ring?
  • Panasonic Master
  • 2,460 Answers
It should have been programmed to ring somewhere and it probably is because you have a blinking light. It's programmed from the maintenance console under ICD groups. It's unusual to put an odd line on the 12th port of a card, but it is what it is. Cards come in 8 or 16 ports. Your PTPM or PM will have access and programming instructions.
Carl
Posted on Mar 24, 2011
I have tried every configuration of the wiring I can think of. I have 2 jacks and a Ring Selector for the fax machine.
What is the make or brand/model of the phone you are referring to? Does it has a line 1/2 selector or a ringer selector on the panel?
Maybe the phone you have has a selector on its side.
I need more info.
Best regards.
Sep 01, 2015 | Lands Phones
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    HP LaserJet 3055 .fax not working
    Direct Line:
    1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
    Dial the number and observe weather extension phone is ringing?
    A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
    B. *Extension phone is ringing no message displayed on device replace "LIU" card..
    If extension telephone is not ringing check telephone line..
    No out going faxess:
    *Check line is connected though EPABX , if connected Check..prefix setting..
    *Check out going..
    Best of luck...
    Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
    How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
    Setting the Ring Delay
    The Ring Delay sets the number of times the
    MFC rings before it answers in Fax Only or
    Fax/Tel mode. If you have extension
    phones on the same line as the MFC or
    subscribe to the telephone company’s
    Distinctive Ring service, keep the Ring Delay
    setting of 4.
    (See Operation from extension telephones on
    page A-4 and Easy Receive on page 4-3.)
    1 If it is not illuminated in green, press
    (Fax).
    2 Press Menu/Set, 2, 1, 1.
    3 Press ▲ or ▼ to select how many times
    the line rings before the MFC answers
    (00 - 04).
    Press Menu/Set.
    (If you select 00, the line won’t ring at
    all.)
    4 Press Stop/Exit.
    Initial Setup
    1.Receive Mode
    Current Receive Mode
    Fax : Fax Only
    F/T : Fax/Tel
    TAD : External TAD
    Mnl : Manual
    Setup Receive
    1.Ring Delay
    Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
    How do you get a t7316e phone to ring
    Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
    To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
    At the terminals&sets prompt,
    press the show key (top right arrow).
    The display should now ask for an extension number. Enter extension number you wish to program ringing on.
    Press the show key (top right arrow)
    The display should sat LINE ACCESS
    Press the show key (top right arrow) .
    The display should say LINE ASSIGNMENT.
    The display ask for a line number. press list
    The display should say line 001: appear only
    press the Chng key till it says appear & ring
    press next key (lower right arrow)
    The display should say line 002: appear only
    repeat the procedure the same as line 001 for the remaining ringing lines
    press the release key when finished
    Dec 11, 2009 | Nortel T7316E 2-Line Corded Phone
    On my phone system (M7310) I only want one phone to ring when calls come in. currently 2 ring. how do I turn the other off?
    Programming is done on M7310, M7324 and T7316 sets.
    To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
    The display should say line 001: appear & ring
    press the Chng key till it says appear only press next key (lower right arrow)
    The display should say line 002: appear & ring
    Nov 10, 2009 | NorStar Meridian M7310 Phone
    THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
    The 4 top line/feature keys are now used for programming2.gif.
    press next key (lower right arrow)The display should say line 002: appear only
    repeat procedure for remailing active lines
    If your system uses the older programming template,
    then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    the display says A. Configuration
    the display will say1. trunk/line data
    Press the next key (bottom right arrow) .
    the display will say 2.line access
    the display will say line assignment
    Press the next key 2 times(bottom right arrow) .
    The display should say ringing.
    Press the show key (top right arrow).
    the lines should be listed as appear only change to appear and ring
    press Rls when finished
    Oct 23, 2009 | NorStar M7208 Corded Phone
    Stop ringing at main phones when outside calls come in.
    Here is a link to program line ringing.
    It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
    From any display phone, press Feature 11
    then enter your extension number 2 times. So if you are extension 20, do this:
    Feature11-20-20
    see if that does it.
    May 28, 2009 | Lucent PARTNER18 Corded Phone
    Machine shows "phone off hook"
    Hi there
    check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
    Regards AL "alstech"
    May 18, 2009 | HP Officejet 5510 All-In-One Thermal...
    Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
    Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
    May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Panasonic KX-T7630 Corded Phone Logo
    47 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
