Question about Whirlpool Aquatic Infinity 1 66X66X25 White AI1INF6666
We filled the tub with water that was too hot. When we pushed the on switch, it shut off and tripped the breaker. it gave an error code of "R20" I called aquatic and they said they don't know what that means. We waited 30 minutes and turn the breaker back on. pushed the on button, but it keeps tripping the breaker and giving the same error code number. We emptied the tub and filled it with cold water but the same thing happens, triping the breaker.
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
gaeb7
  • 25 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
  • 659 Answers
SOURCE: The cold water won't turn off on our Bathtub
Sounds like you have a faucet that has a stop that is on the handle and it has broke. Remove the handle and turn the stem on its own. If you end up having to replace the stem, you will need to turn the water off to the faucet and if it is in the tub, you will need to turn the water off to the house. Hopefully this helps you.
Posted on Apr 09, 2009
  • 4 Answers
SOURCE: Whirlpool Duet Sport Dryer PF code
I just posted this webpage that has the answers to your problem.
https://sites.google.com/site/duetsportpfpowerfailure/
Posted on Apr 18, 2009
  • 44 Answers
SOURCE: Whirpool Range suddenly tripping the circuit breaker
It could be one of the elements is shorting out causing the breaker to trip. Try using one burner at a time to see which one causes the short.
Posted on Aug 21, 2009
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
I have a Dream Maker X400 hot tub that wasn't used for a year or so, I replaced all of the jet heads and filled it - when I started it the light starting flashing on and off with a clicking sound coming...
Hello, and thanks for the question. Your error code is actually "SN" not "5N" but they are sometimes difficult to discern on the LCD topside display. The SN error code is for a Non-functional High temperature sensor which automatically kicks the heater off and trips the breaker. You can purchase new sensors for $75-$85 (it could be more, my pricing index is quite a few years out of date) I'm not sure where the sensor is located in that particular tub, although it is most likely in the heating canister. Make sure the power is off at the breaker before attempting any tub repair. if you have shut-off valves to the heating canister you may not have to drain the tub, remove the heating can and replace the sensor you will have to plug/unplug the sensors from the power pack/circuit board. I hope this helps =)
Oct 27, 2013 | Pool & Spa
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
Jun 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
Washer tub filling with water - after returning from a weekend trip, we found water in the tub of the washer. Used the "Drain/Spin" cycle successfully, but two days later found the same problem...
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 18, 2011 | Kenmore 42822 Front Load Washer
Quiet pak 4 shows code 20 it will fill up and wash 2 minutes before it throws a code
"F20" error code is indicating that no water is detected entering the machine or the pressure switch trip is not detected. If after 30 seconds of filling with water and the minimum of 0.11 of water is not detected entering or the maximum fill time of 16 minutes is exceeded, the valves will turn off and the error code will be displayed. It is an indication that you either have no water coming into the washer, or very little water at all. If you have verified the water pressure is fine, you may have a faulty Flow Meter. You could remove the cold and hot water supply lines, after shutting the water off of course, at the washer and then look to see if the filter screen is restricted inside the water inlet valve on the washer.
The first would be to blow through the pressure switch hose towards the tub. You should be able to blow through the hose without much force. If the air trap the hose is hooked up to is blocked then the pressure switch will not see the water entering the tub. With the tub empty blow through the hose and then hook it back up and see if there is any improvement.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Kenmore Washing Machines
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Aquatic Infinity 1  66X66X25 White AI1INF6666 Logo
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
