Question about Toshiba HDDR320E04XW 320 GB USB Hard Drive
How can I back up the hard drive at one go - Toshiba HDDR320E04XW 320 GB USB Hard Drive
  • Toshiba Master
  • 27,725 Answers
depending on your operating system this may vary click start control panel you should see system security tab in that back up my computer in windows7or all programs accessories system tools you should see back up in xp
hope this helps
Posted on Mar 24, 2011
External hard drive format recovery
They are probably still there if you have not written any new files to the drive. read this link http://www.tomshardware.com/forum/285728-32-data-back-formatted-drive-recovery
Dec 22, 2014 | Western Digital Computers & Internet
I backed up my system and recently lost the hard drive. A new hard drive was installed, and I connected my Verbatim to my PC, but I have no idea how to put all the backed up data back to my PC. Can you...
All you need to do to backup the files on your old hard drive is by using a Hard Drive Docking Station. you can take your hard drive to a local store and ask for a docking station that would fit on your hard drive, the docking station is like a device the you can connect to your computer using a USB cable.
Once you have it, your old hard drive will just function as an external storage device.
Jun 29, 2011 | Verbatim (96759) 1 TB USB Hard Drive
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
REAR FAN FAILURE DELL OPTIPLEX 755
This is the rear fan
Replacing a Hard Drive Fan
  1. Follow the procedures in Before You Begin.
  2. Remove the computer cover (see Removing the Computer Cover).
  3. Remove the hard drive (see Removing a Hard Drive).
  4. Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
  5. To remove the hard drive fan:
    1. Lift the release tab on the back panel of the fan.
    1. Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
    2. Lift to remove the fan and its back panel from the hard drive bracket.
klamma16.jpgReplacing a Hard Drive Fan
  1. Follow the instructions in Before You Begin.
  2. Remove the hard drive (see Hard Drive).
  3. Remove the hard drive fan:
    1. Remove the screw that secures the fan release tab to the hard drive bracket.
    1. Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
    2. Lift to remove the fan from the hard drive bracket.
    3. Unplug the fan.
May 30, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
Oo.comhi. if i delete my files from SDR-H85 PANASONIC how i will recover back without problem. i did with one program but didnt help.
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
Apr 10, 2011 | Panasonic SDR-H85 Silver 80GB Hard Disk...
The hard drive will make a clicking noise, and randomly lag then crash. When I restart, it will sometimes say "unable to boot from hard disk. please insert a bootable drive".
Your hard drive is dying. The best thing to do would be to immediately back up any files you want to keep onto an external hard drive. Replace the hard drive and restore your files. I'm sorry for the bad news but I hope this helps.
Mar 02, 2011 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Restore point lost
go to my computer and then click on the icon for that drive. look for the back up files dated july 3rd. if they are not there your back up failed at that time.
robert
Sep 02, 2009 | Iomega (33090) 250 GB Hard Drive
PAGING FILE ERROR ON HARD DISK DRIVE
You don't install backup files; they're just files.
What you want to do is back up files to a portable hard drive. Then you want to find the backup files on your D drive and delete them.
The biggest commonly available flash drive is 8gb. That's enough to back up your word processing documents and such, but not enough to back up your entire computer. It's may not even be enough room to back up just your music files.
A 1tb external hard drive runs less than $150 now, mail order, delivered.
Dec 05, 2008 | Microsoft Windows Vista Home Premium with...
My hard drive is clickin and I cant access any of it
You will probably need to get profession help in your area to ge tthe data back from the dead drive.
Jan 03, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Toshiba HDDR320E04XW 320 GB USB Hard Drive Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
