Question about Kenmore 22422 Top Load Washer
Washer did not stop filling up with water. Machine started as normal and then kept running but water kept filling into machine and out everywhere in my condo. I think it overflowed the inside tub where the clothes are and then out the bottom. Pushing the slector button in stopped the water and is how it sits right now. I cannot find a model number for it. top Load, about 10 years old. Heavy Duty Ex Lg capacity
    Genius:
  • 1,114 Answers
You will need to replace the control panel to resolve this issue.
Posted on Mar 24, 2011
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
The washer keeps filling and won't stop. Sometimes can get it to stop on the wash cycle but won't stop filling at all on the rinse cycle. Any solutions?
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Sep 12, 2009 | Maytag Performa PAV2200
Water does not shut off!!!
Check the timer in the back behind your knobs make sure it is working. That timer times how long for the water to run on all your settings and for everything else
Feb 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Washer will not stop filling up
take the 2 screws out of the control panel, either in the front or back, depending on model. You may need to remove covers on the front of the panel. flip up the console. Find you water level switch, on the back of the switch there is a rubber hose. Pull the hose off of the switch and blow into it. if there is water in the machine you should here air bubble out as you blow. this should clear the line from any blockage. The machine should operate normally. most likely lint or something blocked the pressure hose.
Jan 31, 2008 | Washing Machines
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
Washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Jul 17, 2007 | Kenmore 22442 Top Load Washer
Kenmore 22422 Top Load Washer Logo
125 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
