Question about Bose QC15 Headphones
No Vocals on QC15 Headphones. Can hear guitar and other audio but vocals are either absent, muted, or garbled.
Am using a Samsung HT-e750W ampiflier. When i play a dvd i can hear the music but no vocal sounds
The vocals are directed to the centre channel. If this is not connected or the connection is poor then it will mute the sound of the vocals.
If you want you can select stereo mode when listening to just music. Not the surround modes. Or you can check the centre channel is working and not switched off. Some amps have the ability to switch speakers off in different modes or settings.
May 12, 2018 | Samsung Audio Players & Recorders
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Can't hear vocals on microphone
go to your control panel ... select sound (speaker icon) and make sure the microphone is not muted.
May 27, 2009 | Magix Music Studio 2005 Deluxe for PC
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Gh world tour mic has terrible lag
Yes, unfortunately, USB ports just aren't fast enough for live vocals. Some stereo setups have longer lag times than others, as well. A couple of ms is very noticeable. Have you tried adjusting the settings on the game? Go to "Options" on the Home Screen and select "Calibrate Lag." Here you can delay either your Audio or your Video in 1 ms increments to try to adjust for lag times. You may find a happy medium after adjusting these settings.
Dec 28, 2008 | Activision Guitar Hero World Tour Guitar...
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
Bose QC15 Headphones Logo
208 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
