Has a Ricoh copy machine, model Aficio-250. Machine is requesting that operator reset the "fusing unit". Operator needs instruction on how that's done.
  • 384 Answers
Hello There and Welcome to Fixya.
The best guide for you to replace the fusing unit of your Alficio250 copier is to see it through the service manual which I included here :
Ricoh Service Manual
This is the complete user's/service manual that includes troubleshooting and maintenance for complete care and avoidance of further issues. And Yes, it is downloadable for your perusal.
Hope this helps, and Thank you for using FixYa.
Posted on Mar 24, 2011
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Pasword on photocopy
Read the manual.
Get online and got to www.google.com In the google search box type: "Ricoh Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manual.
May 30, 2012 | Ricoh Aficio 2027 All-In-One Laser Printer
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
Service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Jan 28, 2009 | Ricoh Aficio 1085 Laser Printer
Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Oct 27, 2008 | Ricoh Aficio 250 Copier
Ricoh Aficio 250
unplug and them plug back in
Jan 10, 2008 | Ricoh Aficio 250 Copier
116 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
