Question about Frigidaire FRS23R4A Side by Side Refrigerator
The fridge side freezes up. not sure why. they told me it could be the defrost timer control board ???please help
  • 132 Answers
I would say it is a thermostat problem.
If it was a defrost problem the fridge would not be cold.
A new thermostat will fix the problem
Posted on Mar 25, 2011
Defrost Timer
Probably a control Board problem. Without model #, I can't say for sure, but your fridge probably has a defrost board and not a timer.
Sep 05, 2017 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Goes into defrost to long, thaws stuff out then starts freezing again
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You will need to change out the defrost timer/control board....
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | GE PCF25PGS Side by Side Refrigerator
My Maytag MSD2756GE is not cooling on the regrigerator side but is freezing ok. What could be the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 13, 2009 | Washing Machines
Refrigerator freezer is not freezing,ice accumalates on one side of the back wall
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle
Sep 16, 2009 | Refrigerators
Frost free fridge freezing up
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator side is barely cool but the freezer side is freezing properly. Thermostat is turned up to "9"
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
Aug 19, 2009 | Refrigerators
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Samsung fridge rs52530bwp the fridge side will not work
I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge is freezing up. not going thru defrost cycle we have a side by side ge fridge and it freezes up and we unplug it letit defrost and it will be fine for few days.& then is does it again; we...
The defrost heater must be replaced when the defrost T-stat is replaced.
The main control board located on the rear of the fridge controls defrost sequence.
May 15, 2009 | General Electric GSS25JET Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS23R4A Side by Side Refrigerator Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
