Question about NEC MobilePro 900 Handheld
I just purchased an NEC MobilePro 900 and I can't sync it to my Windows 7 laptop.
    New Friend:
  • 104 Answers
Install the driver of your mobile in laptop
Posted on Mar 24, 2011
I cannot get my nec mobile pro 900 to sync with my laptop i downloaded activesync from: http://www.microsoft.com/windowsmobile/en-us/downloads/eulas/eula_activesync45_1033.mspx?ProductID=76 i downloaded...
Which one did you do first: Did you install ActiveSync 4.5 first, or did you try installing the driver first?
The best way to do this is as follows:
  1. Download and install ActiveSync (4.5 is what i use both at home and work and it works great with the NEC 900 and 900C's.
  2. Restart your Windows XP Machine (I assume you don't have Vista)
  3. Next, follow the instructions for the installing the NEC 900 usb drivers (these drivers should be installed AFTER installing ActiveSync... (it seems to work that way without problems for me).
  4. Next, restart your xp machine again.
  5. Now, connect your NEC MobilePro 900 to your Windows XP machine, and it should perform smoothly.
If this does not work for you, you can contact the folks at usedhandhelds.com, they sell and repair, as well as provide support for these machines.
Hope this helps
Apr 17, 2009 | NEC MobilePro 900 Handheld
Sync probl
Windows Vista is a nuisance, in my own experience.
it has too many issues with drivers et,c.
i,d suggest seeking the setup cd, that would have been packaged with your Hand-held, Or PDA.
This would have had various Applications on it. And Also Active-Sync 3.5. However Vista. Will probably run or use Active-Sync 4.0. which is available from M$ Site. if you download from a computer running Windows 2000 Or XP. then put onto a memory card, or burn to a CD. that you can then install onto your PC.
Long-term, i,d suggest Considering XP. as a more stable and reliable Operating System.
Hope this Helps.
Mike @ Compurepair.
Jul 23, 2008 | NEC MobilePro 900 Handheld
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
Mobilepro 900c won't sync
I'm having the same problem. Sorry man. I'll let you know if I find something out!
Zach
Nov 23, 2007 | NEC MobilePro 900 Handheld
Getting connected
What kind of Drivers? USB sync Drivers or Orinco Wi-fi Drivers? Try here for USB to Computer Drivers if you have Windows XP: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip. The full CD contents that come with the Mobilepro can also be downloaded from the same page. For Wi-fi Drivers, I THINK the Agere Wi-fi Drivers will work, although I may be mistaken. Try them Here: http://www.hpcfactor.com/support/cesd/h/0031.asp
And any MiniUSB cable will work with the Mobilepro
Aug 12, 2007 | NEC MobilePro 900c Pocket PC
Error message "Backup Battery Very Low"
The MobilePro 900 back up battery is low and should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the "MobilePro 900 Handheld PC's User's Guide" for detailed replacement instructions.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Obtain the USB drivers
You can obtain them from the Apps and Driver CD that was shipped with the device or download them here: Windows XP USB: ftp://ftp.necsam.com/pub/MobilePro/900/WinXP_MP90-USB.exe Windows 2000 USB: ftp://ftp.necsam.com/pub/MobilePro/900/Win2k_MP90-USB.exe
MobilePro 900 turn on during the night and not shut back off
Devices running Windows CE 3.0 turn on at midnight to search for appointments for the coming day. Reminders are set and the Today view is updated with the day's events. The device is supposed to turn off after three minutes of inactivity. If a program is running the unit may not turn off because there is activity. The following applications are known to cause problems: * Windows Media player for Pocket PC. * Active Sync * Wireless LAN adaptors NEC has developed a registry patch that has been tested on the following LAN cards. Device Vendor Driver Cisco Aironet 340 Cisco 2.30.11 Cisco Aironet 350 Cisco 2.30.11 Linksys WPC11 Ver 3 Linksys 1.07.29 Orinoco Orinoco 1.02 3CRWE737A 3 Com 2.2.5.0 LA4137 Wireless Network Symbol N/A For additional information see Microsoft Knowledge Base Article – 263719 Click here to download the Power Management update utility. Installation procedure. Note: Anytime a “hard reset” is performed on the MobilePro 900 the Power Management update utility needs to be re-applied. 1. Download the Power Management update utility to local system. 2. Copy the Pwr_Mgt.exe file to the MobilePro 900 desktop. 3. Double tap the NEC Icon. 4. Click OK. 5. With power on momentary depress the “soft reset” on the bottom using the stylus. 6. Delete the NEC Icon on the desktop.
Jack for the external microphone
There is an error in the MobilePro 900 manual (Pages 2-2 and 2-3). The jack on the front of the MobilePro 900 is a stereo headphone jack only. The MobilePro 900 has a built in microphone. There is no jack for attaching an external microphone.
Coin cell backup battery
No the coin cell backup battery is not rechargeable. If the MobilePro 900 back up battery is low it should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the “MobilePro 900 Handheld PC’s User’s Guide” for detailed replacement instructions.
NEC MobilePro 900 Handheld Logo
108 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
