Question about Kenmore Dryers
The idler pulley on my kenmore dryer is squeaking very bad. I greased it and it lasted several months, but now the squeak is back. should i replace the pulley or is there a better "grease" to use that would last longer?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You will DEFINITELY want to replace the pulley!
Kelly
Posted on Mar 24, 2011
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
Our 600 Kenmore Gas Dryer, makes a squeaking sound and the drum does not seem to turn freely!
Instructions Things You'll Need
  • Putty knife
  • Phillips head screwdriver
  • WD 40
tyn-hp.gifGet what you need for every
project at HomeDepot.com
    • 1 Disconnect the dryer from the wall outlet or the breaker/fuse box. Be sure that the dryer is disconnected before you continue.
    • 2 Raise the top of the dryer. You will do this by inserting a putty knife into the crack between the top and front panel. Push against the spring clips to release. There will be one clip on each side of the dryer. Once the top has been released you can disconnect the wires to the door switch located on the right side on the backside of the front panel.
    • 3 Using a Phillips head screwdriver remove screws holding the front panel to the side panels. Pull the front panel away and lift off the bottom clips to remove it completely.
    • 4 Remove the belt from the idler pulley. The idler is located behind the blower/motor unit. When the belt is free you can slide the belt to the back edge of the drum. Lift it straight up to disengage the rear bearing from cradle.
    • 5 Pull the drum out through the front of the cabinet. You will be able to see the drum support ball on the back of the drum and the cradle holding the ball.
    • 6 Apply a generous portion of supplied grease or spray WD 40 into the cradle. In almost all cases, this will resolve your squeak. Once you have greased the drum to your satisfaction, you can reassemble the dryer.
Read more: How to Fix a Drum Squeak on a Gas Dryer ' eHow.com http://www.ehow.com/how_4899504_fix-drum-squeak-gas-dryer.html#ixzz1PYDjwD8h
Lithium grease works best for this.
Jun 17, 2011 | Kenmore Dryers
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
Dryer runs and heats but has squeaking noise. Drum seems to labor mid cycle and then shuts off. If I turn cycle to off and wait unit will resed and begin cycle again with normal heat. Squeaks in on off...
Hello & Welcome to FixYa
The squeaking sound comes when the belt is either broken or worn out and needs replacement or the idler pulley is bad. If you want to do this yourself then you can check this video on YouTube:
Please get back to me if you have any other questions.
Kevin
Jan 30, 2011 | Kenmore 73932 Gas Dryer
Hi my dryer has difficulty in starting to turn the drum at times and just buzzes also it has recently started squeaking. What parts do I need to sort this out. Thanks
Your dryer just needs a new drive-motor and some grease/oil. It would also be a good time to replace the belt. There is an idler pulley that will squeak if it is not oiled. Also, the drum connects to back of the case using a ball joint, it will require cleaning and re-greasing. Make sure to get the vacume out and clean everything on the inside of the unit(even try to get inside the blower case to clean out all of the lint).
Nov 22, 2010 | Zanussi TC7102W Electric Dryer
Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Frigidaire GLGT1031C Dryer
My dryer squeaks loudly when running. I have
Yes .I would say its the jockey pulley @ fault..
Nov 22, 2009 | GE DVL223EBWW Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Loud squeaking problem as the drum turns.Is it possible to fix it myself?
Replace the drum rollers and the idler pulley . You can change them yourself . Be sure to use white grease on the shafts for the drum rollers .
Jul 27, 2009 | Dryers
Squeaks
The most common problems for squeaks on a GE is the idler pulley or (belt tension pulley). There is a teflon bearing in the rear that can cause this as well. you will have to remove the front panel and remove the drum to repair both. you can see if the rear bearing is gone or if the grease is dryed out.http://www.repairclinic.com/0100_20.asp. Good luck
Jul 27, 2008 | GE Dryers
Dryers Logo
70 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
