Question about Toshiba TLP-S10 Multimedia Projector
Projector was working fine, wen tin the conference room today and the unit will not power up (no lights are on) checked power and it is fine. I belvie this happened before and all we had to do was repalce the bulb. Please advise. thanks
  • 85 Answers
Did you confirm the on/off hard switch was in the on position? (My Toshiba has one) No LEDs light up at all?
Posted on Mar 24, 2011
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Jan 18, 2013 | Panasonic PT-AE700U Multimedia Projector
What are possible reasons that the conference phone is not getting power?
If you know anyone that can test the power supply with a digital meter, you can check if the power supply works or not. the power control board on the voicestation might have blown. and If that is the case I wouldnt recommending fixing it. Getting a refurbished or used with maybe 3 months to 1 year warranty isnt that expensive on these systems. getting it fix might cost you about the same. But checking if the power supply is working or not would be the first thing you want to do. If that works. looking for a power supply is pretty easy.
Feb 27, 2012 | Polycom VoiceStation 300 Conference Phone
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Avaya 4690 just flashes red lights and makes a click sound when booting....over and over again Nothing shows on the screen. Was working fine, just moved it from one office to another... now will not boot
This usually means the phone is not receiving enough power. You either have a power issue in the electrical of the new room or the power adapter is not functioning correctly. Try plugging the phone back into the old office to see if it comes up correctly, if it does their is some sort of issue with the electrical supply in the new room. If you have another conference phone try using that power adapter on the non-working phone.
Dec 14, 2010 | Avaya 4690IP Audio Conference
Lamp bulb indicator is red and unit will not light up
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Also, check and clean the air filters.
Jul 17, 2010 | Optoma HD65 DLP Projector
We recently replaced the bulb in my projector, but it continued to flash "replace bulb". Today, it was running fine then suddenly shut down. The power light is on, but the projector is not on.
IF you did not reset the lamp counter, the unit will shutdown. To reset, press the left and right arrows along with the power button for at least 3 seconds. That will reset the timer. Update this if that does not resolve the problem.
Dan
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
NEC Projector
they have a fuse on the power board inside the projector itself, But normally the fuse does not go bad unless their is a dead short in the unit.
Dec 13, 2007 | NEC MultiSync MT830 Multimedia Projector
Toshiba TLP-S10 Multimedia Projector Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
