Question about Electrical Supplies
15hp kohler How much gap should be between the coil and flywheel?
  • 35 Answers
.010
Posted on Nov 21, 2008
How do I hook up a 15hp kohler engine to a 13hp lawnmover
will bolt holes physicaly fit ? if so then bolt to frame and i suggest using blade from new mower on old frame
Oct 15, 2014 | Kohler 15HP Replacement Engine SV470-3200...
How to set timing on 25 hp kohler enging
most of the timing on this type of engine requires the alignment of the dots on the cam shafts with the dots on the crankshaft. Only other timing required would be the coil leg gap to the flywheel magnets. Most of these require approx 12 thousand clearance.
Jul 12, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I just changed a head because of a popped valve seat, put it back together and had no spark, turns over but no spark. Checked for loose connections, wires, safties, but still no spark.
Did you have spark before repairs? Maybe the coil got bumped or ground wire to coil is pinched and grounding out. Check coil gap to flywheel, a standard gap is .005". If everything else checks out you probably have a bad coil.
Aug 09, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler engine 241 as no spark
there is a piece next to the flywheel tha has a magnet and grabs resistence that may need replacing. I had this happen on mine. call your local repair shop and ask. I found the answer to mine on youtube and replaced it in about an hour,
Jun 29, 2012 | Kohler Garden
What is the gap between the coil and flywheel on a 19 hp courage kohler engine
It is not as critical as some think. A regular playing card works great. Place in between and tighten up the bolts, piece of cake as they say.
May 08, 2011 | Garden
Wirer up a lawn mower coil
A coil is simple gap it from the flywheel about the thickness of a business card--attach the ground wire and plug the spark plug in.
Tada!
If yours looks more difficult send me a model of your engine and I will give more detail.
joe
Nov 01, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a k301a kohler engine; i have replaced the coil the points and still get no spark
I would first remove the wires on the oil cutoff on the lower part of engine. If there are two wires to remove from the sender, then take them off and use a small screw or tape them together to make contact. It could be that the oil cutoff is bad, which will be overriding the ignition on switch.////Failing that, presuming you have proper gap on the points, check the air gap between flywheel and oil. Not sure what it should be but you can google for it. let us know
Sep 25, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Craftsman Kohler 15HP 42
it deffenetly sounds like the coil is bad . as the motor increases in temp. the coil pack expands thus loosing positive charge. change it if it has points filr them a little too remove the tartar you should have a sharp blue spark
Apr 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Jul 10, 2009 | Garden
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
