Question about Troy Bilt 175HP Manual 42" Riding Mower
Have Troy-Bilt lawn tractor (42 in/ 18.5hp), problem is when I put it in forward it does not engage. I think it is the drive belt, which is very loose and worn. Any thoughts
    Brigadier General:
  • 3,911 Answers
Find a small engine repair shop and buy another belt, and a tensioner if it is over 5 years old. Oftentimes it is better to take the old belt with you in case they do not have a listing for your tractor. Before you take anything apart use that cell phone camera for a practical use and lots of pics of the belts. That will save you your next question of how do these belts go back on.
Posted on Mar 24, 2011
HOW DO YOU PUT A DRIVE BELT ON A TROY BILT 33"
I think you should go to your local dealer. They will be able to pull up the info you need and they may even print up for you a picture of the way the belt is installed. GOOD LUCK.
Jul 03, 2011 | Troy Garden
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Just purchased Troy-Bilt Lawn Tractor from a friend. Can you tell me how to replace loose transmission belt so it will go forward. Belt is loose.
If you have a lowe's store near you they handle troy-bilt so get your model number off your tractor and they can get you the drive belt and a copy of replacement instructions.Thank you.
Apr 15, 2011 | Garden
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 | Garden
Drive belt on my troy bilt 16.5
I do not think you have been sold the proper belt. It sounds like the belt you purchased is too long. check in your owner manual for the proper belt.
May 15, 2009 | Mtd LAWN MOWER PART # 16998A DECK...
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 175HP Manual 42" Riding Mower Logo
1,005 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
