Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge Side by Side not cooling
My ge fridge is not cooling enough in the freezer or the fridge part. I have it on the coolest settings in both areas, which I have never had to do before, and it is still not cooling the way it should. The freezer is getting to 20 degrees and the fridge is cooling to 50 degrees. Please help. tina
  • 2 more comments
  • cbradlee Aug 03, 2008
    GE Monogram side by side - the freezer is not staying cold enough and I've even increased the setting to 9.
  • kelly682 Aug 05, 2008
    model #esh22xgpb cc freezer cold fridge at coldest setting #9 only 53 degrees cleaned back of fridge did not help
  • karenuria Aug 07, 2008
    the freezer side works great the refrigerator side is warm Ice build up on the back of the freezer?
  • Anonymous Mar 18, 2014
    the freezer seems to be fine but the fridge is now at 50 degrees
    Champion:
  • 210 Answers
Check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Posted on Aug 04, 2008
Ge side by side not cooling properly
Posted on May 03, 2011
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Hi my GE side by side fridge is not getting cold enough
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
My GE refrig is side-by-side & 15 yrs. Freezer is good, refrig is not cooling good. its 55C instead of 35C on the coolest setting
Check the evap fan inside the panel in the freezer. Try giving it a spin and a drop of oil. Replacement fan runs about $95
Aug 11, 2009 | GE Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Apr 06, 2009 | GE Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
843 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
