Question about Bosch Washing Machines
I have error code E5 on my Bosch Maxx 5 washing machine. I would be grateful for a definition of this code. Thank you.
  • 1294 Answers
SOURCE: Bosch Maxx Instruction Manual
Click on washing machines above, then yr model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site
Posted on Jan 22, 2008
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
SOURCE: i need a manual for my maxx 6 bosch washing
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Go to this link. Just downloaded one for my Maxx7
Posted on Oct 03, 2009
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Posted on Nov 22, 2009
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Showing error E5
this might help: http://www.fixya.com/tags/error_e5/washing_machines/bosch
http://www.fixya.com/tags/washing_machine_error_e5/browse/bosch
or I googled: bosch washing machine e5 error message
Or check your Owner's manual, no manual?
try manualslib.com
Mar 21, 2015 | Washing Machines
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Showing error E5
E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
Jul 29, 2014 | Bosch WAB28060GB Maxx White 600 mm Washer...
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
My Bosch Maxx Clasic says E5 - what does this mean?
please see the next step:
1) turn off the machine, and inspect the water connections
2)This error occurs if the appliance does not take in water or does not do so correctly. Make sure the water intake tap is turned on.3) Refer you instruction manual for aditional idea. if you do not have download from www. retrevo.com or from Bosch.
God bless you
May 16, 2012 | Bosch WFL 2062 Front Load Washer
Washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Nov 23, 2011 | Bosch Washing Machines
How to reset the error codes (F21) on Bosch Maxx 7?
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Oct 10, 2009 | Bosch Washing Machines
Washing Machines Logo
674 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
