Question about Concept P1020 Car DVD Player
Concept p1021 overhead dvd
It read cd but dont read dvd disc. i turn it off for 3-4 days then it read dvd disc for 2-3 days, then it back to the same problem. thanks
3 Suggested Answers
SOURCE: Cocnept 168C DVD Player
I had the same problem. I had to take the cover off and mess with the tray. It was as if the tray had slipped back a bit and so it was not sensing the DVD. I pushed it forward and heard a click and it worked after that.
Posted on Mar 17, 2008
  • 45 Answers
SOURCE: Concept DVD player reads no signal
It sounds like your rca cables are not hooked up from dvd player.
Posted on Jan 13, 2009
I have had this portable DVD player for about one year, it just stop reading the disc. We tr yed to clean it, but it is not reading the disc. Can this be repaired?
did you also test music cd (normal WMA file).
you did? and still no disc.... go to step 3
1- the laser can be bad. If you open the system and locate the laser, check at the back of the laser block for adjustment screws. one is for cd and the other is for dvd reading. adjust one at a time counter- or clock wise the screw with small portion. always test after do this adjustment since you dont use a multi-meter to watch the voltage (between 2.99 and 4.95 volts). sometimes you only have one screw, so that is the only adjustment screw then for both cd and dvd.
2 before adjusting the screw be sure it does only play cd WMA file. If for some reason none of the cd/dvd plays dont ever touch the screws.
3 listen for a high pitch sound coming from the servo motor when the player is reading. does this sound comes on short and then start all over again? this indicate that the motor can not reach its rpm for reading the disc. if your lucky, try e-bay or amazon or an electronic shop for a replacement. any servo motor will do, even if its another brand as long it has the same dimensions.
did you use the player very often if I may ask? How much often (2, 3, 4 dvd's at a time)....
Aug 29, 2010 | TruTech LMD-5702RT Portable DVD Player
Cannot read DVD but can CD?
Could be just a dirty lens. Try :-
1) Blowing some compressed air through it. You can get cans, may already have one.
2) Running a CD lens cleaner. Its practically the same mechanics.
After that, its taking it out and cleaning it.
Jun 06, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Concept car overhead dvd model p1020 wont play dvd
Laser is off track, weak, or just bad. any way it goes it needs to go to the repair shop.
Aug 21, 2009 | Concept P1020 Car DVD Player
Xbox freezes
This is usually because some games are on DVD media and some are on CD media. CD's are single layer media while DVD's are multi layer media. This means it is easier to read a CD than it is to read a DVD. The concept of a DVD is to have several semi transparent layers of data. It is sort of like taking a few CD's stacking them together and smooshing them into a single disc. To read the 2-4 layers of data you must ignore the previous layers and pay attention to ones deeper in the disc. DVD drive might be going out 360 dvd drives do go out more then they should.
Feb 12, 2009 | Microsoft Xbox 360 Console
Cd drive showing instead cd-rw/dvd drive
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My samsung dvd rw combo is not reading any DVD. it is only reading cd.
To work around this issue, open Control Panel, and then follow these steps to configure the DMA/PIO settings for a controller: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand IDE ATA/ATAPI Controllers. 3. Right-click the controller that you want to configure DMA/PIO settings for, and then click Properties. 4. Click the Advanced Settings tab. 5. In the Transfer Mode box, click either PIO Only or DMA if available
Troubleshoot DVD problems loadTOCNode(2, 'moreinformation');
Jul 19, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Marantz DV-6500 problem
Could be the laser Try cleaning it and if not Try and get it repaired Unless you wan't to buy a new one
Aug 03, 2007 | Marantz DV-6500 IN STOCK DVD Player
Concept P1020 Car DVD Player Logo
119 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
