Question about Chrysler Sentry Key Immobilizer Bypass for Remote Start
We understand that your problem is: Dodge truck immobilizor issue. It has happened twice now. First time I thought the Bat was dead. took it off to have it tested it was good. reconnected bat and it started, this time I just disconnected bat and then reconnected it started. I talked to dodge and of course they can not do anything unless it wont start and I have to tow it in. I have 2 questions. First how long after rest will the computer have a fault again? and two any ideas of what they can test prior to it not starting again..
    Problem Solver:
  • 18 Answers
Unfortunately the 555CW bypasses were horribly unreliable, and they seemed to be worse with specific years and models of vehicles. Even temperature change effected how well they worked and there really isn't any way to tell if/when they would act up or work right. They were quickly discontinued since most of us installers refused to use them. There are a couple bypasses available right now that would work much better. I'm not sure what the model and year of your truck is, but the PKALL bypass is a programmable module that works on most daimler chrysler vehicles and doesn't require you to give up a key. If you want a quick easy bypass that's really cheap you can use a TBX-Key bypass. They're a universal transponder key bypass that works for every vehicle and they're inexpensive, the downside is you have to give up a key for that one.
If you have a newer Dodge you can use a DBALL module although that particular one requires a firmware update specific to the year and model and you'd have to go to a shop/dealer that sells DEI to have the module flashed to the appropriate firmware. Installation on bypasses same with any remote start/alarm system is pretty specialized and technical so unless you have a fair amount of experience with car electrical you'd probably want to have it done at an authorized install shop. Don't go pay a Dodge dealer for repairs, they'll charge you an arm & a leg with the end result probably being the system removed. Hope that helps.
Posted on Apr 02, 2011
1993 DODGE HAS NO ELECTRIC POWER TO ANYTHING, BATTERY IS GOOD
CHECK FUSES, ALL POWER COMES FROM BATTERY, SO, INSPECT ALL WIRES (RED) FROM BAT & ONWARD, CLEAN OR REPLACE IF NECESSARY, ALSO, CHECK ALL GROUNDS, REPEAT, CHECK ALL GROUNDS !!!!!!!!!!!!!!!!!!!!!!! POWER HAS TO FLOW TO & FROM BATTERY , +POSITIVE SENDS POWER, -NEGATIVE BRINGS IT BACK TO BATTERY, DO YOU UNDERSTAND ? MUST COMPLETE THE LOOP !!! CHECK BAT TERMINALS, CLEAN & TIGHTEN. CHECK ALL CONNECTIONS FOR STARTING CIRCUIT , LOOSE WIRES , FRAYED WIRES, BROKEN WIRES ,, BARE WIRES SHORTING OUT ON METAL SURFACES,, TAKE YOUR TIME, ONE STEP @ A TIME, KEEP IT SIMPLE ! YOU WILL FIND THE PROBLEM, BE POSTITIVE, ITS REALLY SIMPLE ! GOOD LUCK
Mar 16, 2013 | 1993 Dodge Dakota
My battery went dead with no warning
Battery could have a dead cell which happens often in hot weather.
Have you had it tested yet ?
Sep 22, 2012 | 2002 Pontiac Grand Prix
Bas light dodge magnum
Same thing happened to my 2005 dodge magnum. Took it to the shop, we thought it was a computer issue. Flashed the computer and it didn't help. It ended up being the thermostat and some other parts. The shop had to remove the whole front grille to replace a part that went straight through the top of the engine. The part is plastic and had cracked and was slowly spewing coolant all over the engine. The car was basically overheating but so little that it was not evident at first. Once they replaced all of that the lights stopped coming on. Very frustrating to say the least.
Dec 03, 2011 | 2005 Dodge Magnum
My 2003 Dodge Durango has hesitation when giving it gas and a misfire in cylinder 8. PO308 code. I have replaced all plugs numerous times (Champion Copper plus as recommended by the dealer). I have...
I had a dodge dakota that was misfiring at anything above 3000 rpm turned out to be the crank position sensor, next time it happened the truck would not start at all I replaced 2 crank position sensors over the time I owned it.
May 06, 2017 | Dodge Durango Cars & Trucks
My lexus E350 battery goes dead if car is not used for a week. Had the battery checked with dealer says it is OK
This has happened to me TWICE in the past 4 months. I had Lexus road side service come out both times to check the car out. Each time the battery was totally dead. The road side mechanic said that if the car is not driven at least 15 minutes nonstop a day, the battery runs dead as there are so many draws from the car on the battery. If you do alot of stop and start driving like I do, that isn't enough to recharge the cell of the battery, it must be non stop driving time. Recommend that I get a 1.5 tricky charge device an hook to battery at least one night a week to keep the battery charged. This is really frustrating with such a new car. I've spoken to other owners of other model luxury cars and no one has had this problem.
Sep 13, 2010 | 2007 Lexus ES 350
2004 lincoln twon car alarm keeps going off four times two days watched it happen twice calm day no movement. had battery changed today... could that have solved it... went off just before they took the...
factory alarms sense changes in voltage in the system. If you have recently plugged in a gps or other device in the cigarette lighter it may cause a voltage spike or increase in draw that the alarm system is detecting and that sets it off. Try removing all aux devices from power when you leave the car and see if that works, why did you replace the battery, was it going dead not holding a charge, you could have a problem with your electrical system. an open circuit or ground problem somewhere.
Nov 29, 2009 | 2004 Chevrolet TrailBlazer
2000 Dodge Durango Starting/Stalling Issue
I would start by inspecting and cleaning the battery terminals.
Jul 21, 2009 | 2000 Dodge Durango
2002 dodge ram 1500 flashing red light and dead
When you disconnected the battery, you tripped the alarm which locked down everything. In your owners manual, look under the security or alarm system. It will tell you how to disarm your particular alarm system. If I am not mistaken on these you put the key in the drivers door and lock and unlock it 2-3 times. If you do not have the owners manual, you can contact dodge and they will walk you through it.
Apr 10, 2009 | 2003 Dodge Ram Maxi
A short?
Hi! U need to check the electrical system.Some thing is shorting out(going to earth) causing the battery to go dead.
Jan 29, 2009 | 1995 Dodge Stratus
2005 Dodge Magnum w/out hemi stalling
I have a 2005 Magnum and was also having this problem. Stalled out a few times and continued to idle rough and feel like it was going to die when I would slow down. At times it would feel like I would get a hesitation and then a surge. Engine light would go on for a day or so, then go out for a few days. First time I took it in, the dealership told me that it was a broken seal (I don't know where), but they replaced it and it continued to happen. The second time I took it to a mom & pop shop, and they told me that it was the oxygen sensor/altimeter, replaced it (only a $35 part), and I haven't had a problem since. That was 6 months ago. Hope this helps...
Jul 23, 2008 | 2005 Dodge Magnum
Chrysler Sentry Key Immobilizer Bypass for Remote Start Logo
141 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
