Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsmand garage door opener
I have lost my manual and need to change the code on my garage can you help
    President:
  • 1,779 Answers
You should be able to go to the manufacturers website and download the manual. good luck! countrycurt0
Posted on Aug 05, 2008
How do I change the code on my garage door opener. Have one and lost one.
Press an hold the learn button on the garage door opener for 10 seconds. You will notice an amber LED either next to or above the learn button. When the LED goes out the anything that was previously programed will be deleted. Now press and release the learn button once the amber LED will come on steady. Now press the button on the garage door opener you want to program to the garage door opener. You will hear a click and the light bulb on the garage door opener will go off and come back on. Your garage door opener remote is now programed with a new code.
Feb 22, 2015 | Chamberlain Televison & Video
Myt 1/2 hp craftsmand door opener clicks and light
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that needs to be lit and not flickering for them to work. They must be pointed at one another for the lights to be on. Tweak them a bit and see if the lights come on. If not you likely have a bad sensor.
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Manual is lost need assistance with programming garage door to open from car
the garage door is coded with tiny switches to code with the remote if you lost the code make sure the codes in the remote is in sequence to the garage door remove the cover and look at the code and as well on the garage door motor area is a box cover remove this and ensure they match correctly
Sep 06, 2009 | 2002 Mitsubishi Diamante
Craftsmand garage door will not close. It comes down to about an inch away from the garage floor and then returns to the open position.
If the main light flashes 10 times when this happens it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them to get the lights on.
Jun 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsmand garage door opens radomly
More than likely, someone else has a garage door system with the same or similar frequency. You may want to try to reprogram the code on the unit and remote devices.
I Can Fix It!
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
74 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
