Question about Dryers
I have an electric dryer but my new house is wired for a gas dryer, how do I go about getting the proper plug?
    Scholar:
  • 97 Answers
Hiya
are there no other electric sockets around where your dryer wil be going?
the only thing you will be able to do is plug it into an extension lead, just make sure that it is the correct amps for the dryer.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 03, 2008
What do you do if your out let for your house is only putting out 110 instead of 220 at the outlet.
Depends ... what is 'normal house voltage' where you live?
If you are installing a new electric dryer in the USA, typically, they operate at 220 Volts. If there is no special outlet at the place where you want to use the dryer, you will have to have an electrician install the proper gage wire and outlet for you. Expect to pay up to $200.00 or more for this installation from the house main panel to the dryer location.
If there is a gas line at the location, you may want to consider exchanging your electric for a gas model.
May 27, 2011 | Kenmore 700 6973 Dryer
THE DRYER IS TURNING BUT NOT GETTING HOT,I PUT A NEW CORD ON IT.
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Roper REX4634KQ Electric Dryer
The dryer is turning, but it isnt getting hot. I put a new cord on it!
Is this dryer electric or gas heated...if electric...did you wire it properly...electric dryers use 220 VAC and have a very large plug on them...usually there is a black, red. white, and green wire...the white is neutral, the green is ground and the red,black are the L1 and L2 hot leads...these need to be wired to the 2 hot terminals in order for the dryer to function properly
Dec 30, 2010 | Roper Dryers
We just moved and this house has a 4 prong dryer plug and our last house had a 3 prong dryer plug. We bought a new plug and hooked it up as it says and still nothing. Any help would be much appreciated!
You may have inadvertently incorrectly wired the dryer power cord. The following link epxlains the differences between the 3-wire and 4-wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Make sure you have the wires connected properly at the terminal block. Pay particular attention to the difference in how the ground and neutral wires are connected. If you have any questions, please post back and let me know. I hope this helps you.
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
The dryer runs, but there is no heat. Gas is
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Aug 20, 2009 | Kenmore 700 6972 Dryer
Dryer doesnt heat up
I have provided a checklist for both gas and electric dryers, courtesy of; www.repairclinic.com.
They also provide repair parts, disassembly diagrams, and instructions.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric Dryer Checklist:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Gas Dryer Checklist:
Igniter
Gas valve coils
Thermal fuse
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 14, 2009 | Maytag Dryers
There is no heat but the cycle runs it's normal time and stops when time runs out.
I have provided the following checklists for both gas and electric dryers; courtesy of www.repairclinic.com. They also provide repair parts, disassembly instructions and diagrams to help assist repairing your dryer.
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Gas Dryer checklist:
Igniter
Gas valve coils
Thermal fuse
Jul 14, 2009 | Dryers
No heat
If you have an electric dryer read the top half of my message, and if you have a gas dryer read the bottom half.. Get back if I can be of further assistance:
If your ELECTRIC dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
FOR A GAS DRYER:
Igniter
Gas valve coils
Thermal fuse
May 21, 2009 | Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
