Question about Canon Office Equipment & Supplies
I need to clean the head on my PIXMA iP3000 every time I wish to print colours. I think it may need a new print head, but can get no help on the Canon website. Can you help
SOURCE: canon pixma inkjet ip3000 driver
i lost my installation disk too... tell me the site where i can find the installer to install my printer
Posted on Oct 04, 2008
hashchathy
  • 246 Answers
SOURCE: Canon Pixma iP3000- How to Clean Heads
if you have the uninstall programe use to clean it.
Or use the add remove programe to clean this programe
Posted on Jan 08, 2009
  • 258 Answers
SOURCE: IP3000 WILL NOT PRINT BLACK
Try Start --> Control Panel --> Printer and Faxes
Right click on the printer --> slect Properties
Look for maintenance and try "clean" or "Deep Cleaning"
If you cannot find "Maintenance" look for "Tools"
Posted on Jan 13, 2009
cene765
  • 787 Answers
SOURCE: Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Posted on Oct 15, 2009
I've just replaced the black ink cartridge on my Canon Pixma IP3000 but it is not printing - absolutely blank. However the colour cartridges are printing fine. Any clues?
Assuming a windows computer ... go to the printers section, right click on the IP3000, click on propterties then the maintenance tab. Try cleaning or deep cleaning and then nozzle check.
Feb 01, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet...
The print head may be failing, you would have to send it in for service for a checkup.
Noting wrong with your cartridges its the unit that is controlling them. They 'fail' eventually and cause this.
Got warranty? maybe they will fix it for you free.
Check with canon or your dealer.
Thanks,
Ekse
Jul 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
My Canon pixma ip3000 stopped printing cyan
If you have the orange tape removed from the top of the cartridge, and it's a Canon cartridge, you may need a new printhead. Some of the refilled carts. don't fit properly and it's best to try another before buying a new printhead, but when all is installed properly, and you lose only one color, the printhead is just worn out.
Jan 06, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Cyan ink wont come out
It is probably clogged. You need to using lint free swabs and vinigar to clean it. The vinigar disolves deposits of dried ink.
If this doesn't work then it can be a print head problem and that is usally cheaper to replace the printer than it is to repair it.
Oct 24, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000
canon ip3000 & ip4000 the heads get dirty.
if you keep doing cleanings and deep cleanings it will eventually cause an error because it thinks the tank is full.
take out the head - in the sink, with warm not hot water rinse out much ink as possible. then use windex, the ammonia removes the ink. flush good - shake out head, drops will form on the bottom. keep doing it until drops are clear. rinse with water. shake out well. dry contacts.
I use a water pic as a pressure washer to force water thru. replace head and tanks.
do not use clean, instead print a page of 'X's
make every 5 rows a different color. this way you can see what is working and it won't fill up the cleaning tank, causing a code error.
you can use any ink you want as long as it is the proper type- don't have to be canon
Sep 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing
Try a new tank, there are more and more people getting bad ink tanks. HOWEVER if it is a printer that has seperate heads you might have to change it.
Sep 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Colour of print
A New printer is the most cost effective answer here- they are so cheap No repairs are possible You could check out www.fixyourownprinter.com but you will fiddling around with various suggestions -is it worth it?
Jun 16, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
old marine
old marine
