Question about GE Refrigerators
My GE Model GSS201ETA, Serial # VL204167 does not dispense water. The ice maker works good. There is no water filter for this model.
  • 50 Answers
I would start by making sure there is water going to it. If so it could possibly be the fill valve is bad. I would first volt out the vill valve supply plug just to make sure it is getting voltage when in use. If so I would recommend replacing the valve itself.
Posted on Mar 24, 2011
I have a GE refrigerator model gfss6kkycss with a Samsung ice maker model DA97-07365A the problem is it is not making any ice and the water dispenser is working fine
-Make sure turn the ice maker " ON"
If it's on then the Water valve to the ice maker might not function.
Good luck
Mai
Oct 26, 2017 | GE Refrigerators
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Changed water filter in ge model gshf5kgxbb now dispenser doesn't work
With some of the GE refrigerators the air that is introduced into the water line keeps it from working until the air works it way out. IF you are sure you change the filter correctly, then just hold down the dispense button for a little time and then let off and then go do something else for 30 minutes or so and then hit the dispense button again. The ice maker will start working when you get the air out.
Jan 01, 2012 | GE F-150 Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
