Question about Frigidaire Kitchen Ranges
I have frigidaire stove model no# 316418306 the oven donot want to work it gaving me a code f13
4 Suggested Answers
SOURCE: frigidaire PLES3890
i wouldnt buy one of these products again never!!!!
Posted on Aug 25, 2008
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Posted on May 28, 2009
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Posted on Oct 21, 2010
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
F13 code on frigidaire stove gas
Disconnect power, wait 30 seconds and reapply power. If fault returns uponpower-up, replace EOC
Jul 28, 2012 | Frigidaire Kitchen Ranges
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
I HAVE A FRIDGIDAIRE STOVE AND OVEN MODEL #PLES389CC SER. #NF54421685 AND WHEN TURNING ON THE OVEN IT GIVES A F 13 CODE. WHAT COULD THAT BE?
Hi.
F13 means Bad EEPROM check, which in simple words means bad oven electronic control. The EEPROM is memory a chip mounted on the ERC board (oven control module). When the board detects that the data stored on the EEPROM is not valid you get this message.
Try disconnecting power from circuit breaker for ten minutes. If that does not work, try longer, leaving oven off for few hours. If that does not fix the problem, then the control module must be replaced.
Regards.
Ginko
May 31, 2011 | Frigidaire Ovens
How to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Model FGFL87DSG error code F13
hi there,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
here is what you can do:
disconnect power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
let me know if this helps.
Oct 12, 2008 | Frigidaire Kitchen Ranges
Frigidaire CPL-EF398DCK
If unplugging doesn't reset it, then EOC electronic oven control is most likely defective
Nov 15, 2017 | Frigidaire fes365e Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
