Question about Stanley Tools 5 - 1/2IN Sliding T - Bevel - 46 - 825
Need to know how to use this tool Stanley 5-1/2in sliding t-bevel, I am cutting trim molding around the top of my bathroom and i know this will give me the angle but do not know how to transfer the angle to my work piece, is there an instruction book, i realize it is probably very simple but i do not have an instruction book. I am going to be using a radial arm saw to cut the angles
    Novelist:
  • 157 Answers
Hello. It may be simple, but the transfer part catches everyone - yes even me at first. For your application, the trick is to:
  1. pull the slide as far as it will go and match the round-to-round end and match into the angle to be cut/trimmed-out.
  2. transfer the angle to a protractor, and match the angle (now a number) to the scale for "blade angle" on your saw.
  3. should your saw's scale be suspected as inaccurate, match the angle visually with the blade to the item's work surface.
Good luck, and if this helped please vote a four thumbs-up.
Thank you.
Posted on Mar 25, 2011
Need owners manual
Go to 2heplu.com you can download operator manuals and parts lists for Dewalt, Black & decker and Stanley power tools.
Mar 12, 2014 | Dewalt 12" Beveling Sliding Compound Miter...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
Do you lay the handle long wise against the wall or the end of the handle??
A sliding bevel is used for transferring an angle. What matters is the angle created between the handle and the slider. For example, if you wanted to cut a piece of wood to fit in a corner but that corner is not 90 degrees true. You would loosen the nut, place the center of the bevel in the corner so the edge of the handle lays flat on one wall and the edge of the slider is flat against the other wall. Tighten the screw on the bevel. Now you can lay the bevel on the piece to be cut and mark the exact cut line so the finished piece will fit perfectly.
The sliding T bevel can also be used for setting an angle by using it with a protractor. lay the bevel on a protractor, lock the screw in place at the desired angle, then lay the bevel on the work piece and mark the cut.
Dec 31, 2010 | Swanson 8 Inch Sliding T Bevel
Cove molding angles
Watch this video...
http://tinyurl.com/pup4zhf
Sep 27, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
What do i do to cut inside/outside corners for crown molding
It is very hard to make proper cuts with one of these.
You may want to buy a power miter saw.
You would be better off marking your 45 degree angle and cutting it freehand.
If you angle your saw a little the face will look like it matches up better.
If you need more help post a comment.
Tim
May 03, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
How do I use an 8" T bevel?
put it against the wall so it touches both walls. Then lock it in place with the nut. Next if you have a power miter saw lay it on the table and move the blade so it lines up with the angle thay you have then it will give you the angle for the cut.
Good Luck
Dec 28, 2008 | Swanson 8 Inch Sliding T Bevel
How to make crown molding with a jet 13" planer /molder
You may want to go to the Forum at OWW (Old WoodWorkers.com). What your attempting to do requires several Passes. I usually Rough out BOTH Face & Bevel, then make 2 more cuts each, to get to the Finished dimensions. I usually start with a Face Cut 1st, leaving some Flats for Square then do the Bevel Cuts to Desired dimension, then back to the Face, & take it down to where the Finished product is where I want it.
Dec 22, 2008 | Wmh Tool Group Jet 13" Planer Molder
Stanley Tools 5 - 1/2IN Sliding T - Bevel - 46 - 825 Logo
175 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
