Question about LG Televison & Video
When I turn on the tv, I get no audio for about 10 minutes and the the picture never comes on. I used the LG online chat and they showed me how to manually reset by unplugging tv, pressing power button for 10 seconds and then replugging tv into the outlet. It worked but the next day, I had the same problem all over again. No picture but audio after about 10 minutes. Can you help?
  • 11,361 Answers
It may have dying power supply tha putting out unstable DC which can cause strange problems or corrupt the CPU inside the TV, hence unplugging the to reset it. You can have it repaired or DIY repair.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 24, 2011
What is causing LG TV 47LN5200 to lose picture and go and stay black at random time intervals?
you seem to have a reasonable knowledge of the problem
it is unfortunate that you still have a problem but the fact is, replacing parts without fixing the original fault will only cause the replaced parts to fail again
it is a good project and will improve your knowledge well past the point where a new tv would have been cheaper
there are manual on the net that you can buy /download that may help and they may show an area not considered that is the original fault
Oct 26, 2016 | LG Televison & Video
The red light turns on but no picture comes on
Get real close to screen and maybe use a flash light to shine on the screen and see if you can see the picture still, it will be dark and almost not visible but you should notice something move. If your screen has picture then you most likely have a back light problem. Most common problems are bad inverters, or the inverter controller card. possibly a bad power supply but most likely inverters, test each circuit, replace as needed.
Sep 17, 2012 | LG Televison & Video
The TV turns on and shows a picture that you can watch and within 10 minutes the TV loses its picture, however, the light is still green. If you turn the TV off you can get the picture to come back after...
The issue here could be a capacitor within the power circuit. Also could be a power transistor that is faulty. On the easy part it could be a matter of reprogramming the unit but I doubt it.
Dec 18, 2017 | Hitachi 42HDT52 42 in. Plasma HDTV
The stand has been taken off need to put back on LT 3050
LG RD- 14CA30M MODEL TV PICTURE NOT SHOWS WHEN HIT THE TOP OF TV PICTURE COMING,1 OR 2 MINUTS AFTER PICTURE GOESE THAT SHOWS RAINBOW COLORE AUDIO OK,,,SOLUTION PLZ
Aug 20, 2010 | Mitsubishi LT-3050 30 in. HDTV LCD...
TV switches off after 3 minutes
You have a bad Fan,if fan stops turning on while tv is trying to come on lamp will not light and tv turns off.
Nov 24, 2008 | LG RU-52SZ51D 52" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Audio cuts out
HDMI is not a universal standard. Some units will not talk back and forth correctly and can cause lock ups, loss of audio or loss of picture. Try switching to component inputs and see if it works better. Check your owners manual but I believe the component inputs will also accept 1080P as long as the Panasonic Blu Ray can output 1080P. Don't believe what the Salesman said if he told you that you have to use HDMI or you won't get HD.
Apr 19, 2008 | LG 42LB5D 42 in. LCD Television
No Picture but Audio is present
suspect graphics bourd may be a dry joint if it comes and goes
Mar 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
85 people viewed this question
