Question about RCA HD50LPW175 50" HDTV
RCA DLP Replaced the lamp and now the picture is blurry around the edges,i pulled the screen off and cleaned the lense and got rid of the shadows,but i've been reading about mirrors needing adjustment i went to the manual web site and am waiting for there response to my model coverage,any suggestions in the meantime? Any help would be greatly appreciated.
  • 3 more comments
  • hotrodpony Aug 03, 2008
    i didnt change anything but the lamp
    all the settings should have remained the same
    but the picture was perfect the night before the bulb blew,how could that warrent a color wheel change?
    the blurring is more like around the objects that are moving,thats why i thought it may be some kind of focus problem.
    all the colors are fine ,just not the crisp picture it was before i changed the lamp,very frustrating. i dont want to buy something i don't need,
  • RCA Master
  • 19,396 Answers
You need to replace the color wheel.
Posted on Aug 03, 2008
  • 1 more comment
  • Ginko
    Ginko Aug 03, 2008
    It is not a matter of settings, when is dark or blurred around the edges is the color wheel.
  • Ginko
    Ginko Aug 03, 2008
    Check here on how to diagnose and fix mirror related problems
  • Ginko
    Ginko Aug 03, 2008
    only, when it is mirrors or a problem with the light tunnel, you get shadows not blurred areas, if colors are more intense in blurred areas is wheel. If you get shadows is probably something in the light tunnel.
    Guru:
  • 1,894 Answers
Have you adjusted your convergence settings?
if not please do that
Why is picture blurry?
Sounds like a misalignment problem. the lens has a specific optical plane the DLP chip must be positioned at in order to provide the proper focus on the screen. Try repositioning the board or adjusting the lens to clear up the fuzzy picture. Regards.
Aug 17, 2015 | Mitsubishi WD-73733 73" HDTV
Samsung HL-R5688W DLP TV Screen Burn
I don't know where you got the information that burning could not happen but that is completely wrong. If it is a monitor, tube tv, LCD/LED, DLP or any other kind of viewing device it can burn. With that out of the way if the lamp warning is coming on then it is time to replace it but your image problems are deeper than that. The screen appears to be separating. By that I mean there are three layers and sometimes more depending on the manufacturer that display color. Think of it like saran wrap laired on top of each other. As they get old or of poor quality they start to separate and show some pretty funky imaging. Without the TV in my shop I most certainly cannot 100 percent say for sure that this is it but I would strongly consider this as not fixable.
Mar 02, 2014 | Samsung HL-R5688W Type 2 Compatible TV...
TV screen is dark
If the picture is dark then I suspect a bad lamp if you just replaced it...
Nov 20, 2009 | RCA Televison & Video
Recently replaced blown lamp for 50HM67 50 inch tv. Now have picture but clarity is off. Picture / screen words are very blurry. Toshiba referred a local repair company who mentioned that the problem...
If the picture was good before the lamp blew, there might be dust/splatter on the window in front of the lamp. Pull out the lamp assembly and look at the small square glass window that the light shines into. It should be clear and clean. If it is not, clean it gently with isoprophonol alcohol or screen cleaner.
By the way, there is no such thing as convergence adjustment on DLP TVs.
Sep 09, 2009 | Toshiba 50HM67 50" HDTV
RCA 52" HDTV DLP tv
suspect the optical engine as the culprit. they can gather dust contamination internally and cause a "faded or washed out pic"
Apr 09, 2008 | RCA Scenium D40W20 40" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
RCA HD50LPW175 50" HDTV Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
